This was not full throttle, as i wasnt quite enough used to the board to push the throttle all the way. More to come!
I wonder how fast it could go if i put on @onloop ‘s R2 hubs and configured the VESCs for them…
Ooh, and leave a like and SUB, so i can continue with the raw content!
next time point your camera towards the front of the road so we can have a broader perspective
What are the specs for your esk8
IRL Specs:
I weigh 150 lbs, and achiever a top speed of 27mph on flat ground, and a range of 18 miles. uses dual VESCs with 800w hubs. Theyre soon offering belt drive option and higher-end hubs. 25r 10s2p battery
I will be including a standstill->full throttle acceleration and speed test in the future!
Cool. I think you meant 18miles* What does the 25r mean? I made mine own esk8 too but I was too pussy to ride full throttle. My friends got a max speed of 31mph who weighs 140 lbs and my most efficient run was 20miles on 12s 5ah(around 14~mph) How is it that I use one 3kw motor yet you achieved a speed just lower than mine with just 1.6kw?
No idea…
Watts do not determine speed they determine power. Speed is determined by the motors kV, battery voltage, wheel size and gear ratio
