I’ll be looking at the design for sure, @Wajdi can you release a cad to make it easier to mod the case, it may make it a more interesting proposition if there are some good case variations ie just keep the electronics proprietary
For instance I would like to add a 5.5 charger port for a 13s HAYA build, fusion file if you can
When did you order it? I ordered near the end of August.
And it should work with a unity. It’s not that much different than a focbox. I’ll be getting a Unity Friday and I’ll try it as soon as my display ships.
I created shipping labels for all the Proton pre-orders, if you did not get your tracking number, let me know and I will send it to you.
About Unity compatibility, I’m looking into the source code right now, and I will make it compatible either initially or through a firmware update once shipped.
I will also post the enclosure files so anyone can modify to their liking
Ok so kind of an odd question but I think I somewhere read that the proton has an uart splitter… If so how did you realize that? I’m working on one right now and was just wondering
@Mich21050 Pretty easy, just make sure that your microcontroller supports two serial ports, then you just forward commands from one port to the other in a FIFO order.
Would be cool to have a comparison between them. DAVEga is more for the DIYers I imagine, as it doesn’t have a touch screen, everything needs to be programmed first, then the unit needs software flashing.
It’s a cool project though, it’s nice to see “new” products coming out.
Tested with the custom made 1 meter long uart cable (~ 39.37 ") with no problems! I was worried about voltage attenuation and packets loss but it worked perfectly!
