You need to open it in Adobe reader and print it as a poster
I’ll need to make a video tutorial… use Adobe reader and print it as a poster. Anyone here speak Spanish to help this dude??
You print correct. Use tape to join paper together and cut white parts off
(Using simple English to make it easier to understand, not being rude)
Clamp or Glue paper onto cardboard
Imprima todas las páginas en ‘modo póster’. Cortar cualquier blanco de la plantilla. Stick con cinta con precisión. Voila, tienes tu plantilla.
Do any wood stain you like and then do 3 polyurethane coats and fine sand them inbetween coats
Fine grit sanding to smooth it out
Nice job Man. Can I get the loaded template?
Download links are on a post further up
Would I be able to get a loaded tesseract template pretty please?
I’m on vacation for the next two weeks. Will do it once I get back home. Please remind me if I forget haha
can you make a template for the arbor cypher
Will do. I will no longer be doing these after I have finished Deeman’s
sad to see you go
