Ok battery build thread here goes:
Hereās the gist of what Iām trying to achieve:
I grouped the cells in threes and glued them with black hot glue, plus taped the positive ends with kapton tape. Then I spot welded a length of 0.15x8mm pure nickel strip to the positive and negative terminals of each p group. I used fish paper rings on the positive terminals, and trimmed the corners of each strip.
To isolate each p group from its neighbour (and the cells above or below) I cut a piece of 1mm pressed insulation board (like presspahn), and scored a fold in it. Then I shrink wrapped each p group.
I then connected each p group using flat, braided copper speaker wire
For the connections between 3 and four, and 7 and 8 I stripped the insulation from the speaker wire and just wired two lengths of copper braid straight down between the groups. Between 5 and 6, I folded the speaker wire in half.
Complete pack photos:
Link to BMS used:
BMS wiring diagram:
Itās going to be hard to check my BMS wiring, but the key point is that b0 (Black balance wire) is wired to pack negative, and all subsequent balance wires up to b10 have voltages increasing in increments of 3.42v(ish).
One thing that happened when I was wiring up is the battery charge negative made contact with the BMS body and sparked. The balance loom was also loosely touching the BMS balance pins. Because they were only loosely touching, itās possible the current sparked across from the balance leads to the wrong part of the bms.
I think this short significantly damaged the bms. When I connected the balance plug (I think with everything correctly wired) it sparked and smoked.
Iām no electrical engineer, but I believe itās a blown fet?
If the brief short isnāt to blame, the other explanations are:
- I made a mistake in my wiring; or
- The BMS is junk, and what did I expect for the price?
If the cause of the fault was in fact the short while I was wiring up the bms, this begs the question - what is the recommended order for wiring up a bms? Battery negative first, or balance leads?
