You need fish paper
Just did the setup wizzard for ppm control via canbus (2 x Escapes) but i noticed on the bench, that the master motor is running faster than the slave. Is that normal ? I do not use traction control.
Hi, i love the idea of a silent motor and want to try FOC mode. I have a VESC from diyelectricskatwboard. Will it work? Heard a lot of people that fried their VESC using FOC
Feedback on parallel pack design would be much appreciated
Hey, i have found this dual hub esc on ebay, I know it is very cheap compared to others, but, would it be enough for a simple hub build? I have a main board, so this would be just for fun build. https://www.ebay.com/itm/Dual-Motors-Longboard-Skateboard-Electric-Controller-with-Remote-ESC-Substitute/302800207148?hash=item46804c7d2c%3Am%3Am8m_nfFZHQxHy92plGzxnzQ&var=601691512365&_sacat=0&_nkw=hub+motor+esc&_from=R40&rt=nc&_trksid=m570.l1313
You can try it but there are no guarantees it wont stop working while your riding
Hello, i buy thisn BMS with protection on discharge and charge. but i cant find the -P spot like this
My bms:
Did you take the metal plate off
no but, it is safe mount like the seller say? you dont need a -P for safety discharge?
Well that would be the first thing I would try as it could be underneath
That I do not know because I have not seen anyone use that bms most guys on here use bestech
Can I run 10s lifepo4 on a hobby king max6? It’s slightly over voltage. Hobby king live chat said it could maybe handle 35v if the amp draw was not at max. So do I just run 10s slightly undercharged to stay safe or order another bms for 9s and be undervoltage?
yea its ok, just push it back down. the nickel will hold it in place once you’ve welded it
I lost the charging port for my liion battery pack, I was getting a solder joint fixed at a friends and when I went to go home I put it in my pocket. Now it’s nowhere to be found. Where can I get one asap?
Here’s what it looks like: https://imgur.com/rMuIu1f
I bought some hexagon grip tape. I remember seeing a picture in a post here where someone was using a Y tool to evenly apply the shapes. Where would I get something like this?
Thanks a lot
If they say 35v then only charge to that or a little less. Lifepo4 discharge curve is a fairly flat 3.2v. What type of cells are you using and what is their discharge rate.
