So it’s a simple as connecting the two packs together with a plug and play parallel connector? Thanks for the info AreaKruzer.
Yup. Pretty much.
Sweet as, cheers mate.
Hi there, a quick question for anyone using enertion focboxes, where do i connect an external power switch to the unit. Every esc ive used in the past has one built in. thanks in anticipation
you would plug the the focbox into your anti spark switch and then into your battery of your board
thanks man ive sorted it with a battery switch.
Hmm stepped down axle. Must be a noob because I haven’t heard this term before carvon. I’m assuming these speed drives use 10 mm bearings since the 8 mm won’t fit? It’s just weird because the 10 mm fit snuggly around my surfrodz axle like normal but are loose around the carvon axle. I dunno, any clarification?
If anyone cares I got this taken care of. I had to sand the axle on one side down to fit the 8mm
Is there a way to use the dial instead of trigger on a 2.4ghz mini wireless controller like in photo?
Yep, just move the ppm lead to channel 2 in the RX.
Do i have to take it apart?
The ppm lead on the speed controller…
Move it to ch1.
Thanks that was a simple fix. That feels more ergonomic in my hand and i dont feel like ill bump the throttle by mistake youre the man mmaner i mean that to be a fist bump
I’m glad you claified the fist bump
Lol why is there a face punch emoji and not fist bump?
Does anyone have some focbox limit setting suggestions for single motor 10s3p 30q 170kv Sensored foc 16t - 36t pulleys ? Thanxx
It depends on what your motor max is most likely it will be 60a and maybe -40a for motor min. Bat max 45a batt min -12.
