I need a motor that is form 220kv to 270kv with connectors that plug into a Vesc with out switching the plugs out.
What size connectors do you have on your VESC? What size motor do you want? 50mm or 63mm?
Ethier 50mm or 63mm bht I would like to keep it around $50 and I think the bullet connectors are 5.5mm it is what ever comes standard with the @torqueboards vesc.
Ok. I have 270kv 50mm motors with 4mm bullets, but they are new and more expensive.
Thx but I am on a budget they look like good motors though
Yeah it is just to expensive I am looking for used so it will be cheaper
Didn’t you say around $50? This one is only $60!!!
Turnigy Sk3 6364 245 KV. Got it for $70, was amazing on 6s, is still amazing on 10s
Honestly, invest the extra $10, you won’t regret it!! I’m not an expert but a used motor could have issues and if you buy knew you could sell for more than used)
Plus shipping tho
True I think I might
If you are really on that big of a budget, go with this https://m.ru.aliexpress.com/s/item/32792436718.html?spm=a2g0n.search-cache.0.0.2e3c1faahSbx9w but I can not recommend it since I did not try it!
Good luck. Let me know what you find.
I decided to go with a 280kv motor sk3 turningy the kv is a little high but I am fine with it it is for a small budget board to be portable and does not need to be powerful my main board foes 31mph and I have all the power I want in that. It cost 56 plus shipping and is 50mm
