they have not been released yet. He will announce once the 21700 version is available for sale. mainly the tabs are the issue.
Gotcha thanks for the update
he made a new thread, since this thread is not the one he started.
This one is more active these days. Youâll have your questions answered faster. https://forum./t/nese-the-no-solder-18650-battery-system/1777?u=mishrasubhransu
I used old laptop cells for an experiment. They became very hot, couldnât hold a cell in my hands for long. The PLA battery holder became soft and deformed. Good batteries with normal internal resistance do not heat too much and ok to use. Temperatures above 60 degrees Celsius will soften PLA. Interestingly, 60 degrees is the temperature which generally will not cause damage to skin if held in contact for NO more than 5 seconds.
I had a second failure of rigâŚapparently BMS did not balance cells in 10s4p pack, so how does one doâŚbalance in NESE rigs?
Nese module balance wires:
For a 10s4p pack does one use a BMS with 10 wire module?
