It will wipe the motor bearings and can cause the shaft to walk out. Additionally, it can cause misalignment of the wheel and motor mount. Plus, if you have zero slack in the belt, guess what will happen if a stick or rock gets in there…
@chaka and others In your experience do idler pulleys increase efficiency? I would think they would do just the opposite, but I have seen people say otherwise? Curious what you thought.
The benefit of a well-placed Idler simply increases the number of belt-teeth in-mesh with the motor pulley by changing the angle of the belt relative to the motor pulley. In the wrong place (too close to the wheel pulley), an idler will stress the belt system, causing unnecessary strain and decreasing efficiency. The increase of teeth in mesh, for a properly placed idler, allows greater loading capability at reduced belt tension. Trust me, the benefit of a looser belt to overall efficiency is greater than the increased resistance of the additional bearing & belt flex!!
This info is above (somewhere)!!
Apologies for bring back a old thread from the dead but I came across this forum while researching idler pulley setups for E-skates and the information on here was very useful to setting up a idler pulley on my D.I.Y modified evolve so thought I’ll share my setup.
I have some idlers just in case. Never mounted them. I run LOOSE belts. But found that my braking and accel are soft. The belts DONT like flexing in reverse. They are manufactured with the curve.
Perhaps running the idlers on INSIDE. To keep bend right.
The idler pulley works so well on my DIY I want to try and rig something up on my stock standard evolve but I don’t think the standard motor mounts are long enough.
