Will do man! I am interested in making my own on an upcoming project and was thinking either this or 3d print
Did we end up finding out the axle and truck dimensions?
I m interested. What scanner 3d did you use? Can you send me the 3d? It s only one piece, or is separated in more parts? I will modify with solid works.
What dimensions do you need? I can get you whichever you need, as long as I know which ones to measure.
I didn’t use a 3D scanner. I just used a caliper. I have the truck as a solidworks part with separate bodies. Where should I send the file?
If you can confirm that these dimensions are correct that would be awsome?
Pm send thanks
Not sure what your planning but those are some tight tolerances. Below is what I measured. Looks pretty darn close.
Awesome. Yer I didn’t draw that 1st one it was given to me buy someone making a universal truck with screw in axles. I’m planing to make custom axles for a Trampa trucks to accept the evolve drive train.
This thing looks so futuristic and badass at the same time.
Hi. Do you know the motor mount bolt pattern dimensions? Cheers
where did this board get to.!>!?
