@[Paulycnotes]
Do you have the same configurations as chris415? What hubs (wheels) do you have?
@ FredXanadu
I make 15/60 and 15/72 belts transmission
60t pulleys only for Superstar and Megastar
What hubs do you have?
@[Paulycnotes]
@ FredXanadu
I got Matrix 2 mounts… Brand new sick… I need the Matrix 2 pro Trucks…
Let me know if you’re looking to buy mine…
mbs rockstar…
This setup would suit my build love motor mounts and want those trucks matrixll,how much
@FredXanadu, @Ozzie
I have two types of mounts for you.
v7.3 - 130 Euro
or
v6.5 - 150 Euro
Double set of pulleys and belts 15/72t/15mm - 110 Euro
Interested in Motor mounts…
I want to buy them, how can I contact you?
I’m sorry I didn’t answer, I was on holiday and I didn’t get back until this morning.
Can I help you?
I’m interested in your motor mounts for TRAMPA atb
Do you need only motor mountns, or do you need a complete set with belts and pulleys?
Where are you from? What hubs do you have? What motors will you use?
Question about the minispring full set up. Has anyone had you add steel mesh around the motor braces to add protection against gravel and debris? That way they are fully enclosed but still allow air flow.
You probably mean this version of the motor mounts
No, nobody has come up with such an idea yet.
Narrow trucks (mini spring is not the best choice for off-road riding)
minispring is trucks for city driving (Urban carver), and for city driving you don’t need full motors protection, motor mounts in version 7.3 are the better choice for this truck
I recommend full motors protection for mountainboard with ATB trucks
Riding the streets In Baltimore is off roading! No street sweepers and potholes galore! There’s always sand and gravel everywhere. I already have mini springs. Just trying to work with what I got.
These pulleys can fit MBS twistar hubs? If so are the small ones 8mm shaft for the turnigys sk3 aerodrive 149kv? Thanks. Will be interested in a set with these specs.
The twistars hubs don’t have bolts the two hub sections twist and click together so they are no good for adding a bolt on pulley.
It doesn’t fit Twistar hubs Fits Rockstar II, Rockstar Pro, Five star
Yeahhh… I believe Metroboard has a PRESS FIT. Or Jenson and if not Jenson could make one…
What i’d like to see on your next iteration of your mounts is a different angle. I really want my mounts to be higher up (like the trampa mounts)
Hi Idea! I have one of these china boards and need motor mounts for it (I think the trucks are like the matrix old version ?) Thanks.
