A set is $50. It includes 1 clamp (adapter for your truck), 1 universal motor arm, dual idlers with bearings and all stainless steel hardware.
The guy supposed to lend me his Avenue but never delivered.
Oh, that’s unfortunate. You in the US I believe? I would send you mine if in EU Hope someone lent you one hanger for the clamp.
Yes, California USA, anyone out there interested in loaning me your Avenue?
Is it possible to Mount two 6374 on one ronin truck? One Forward and one backward? Would be nice to see some Pictures of two Mounts facing opposite directions.
I don’t have a picture of what you are referring to but yes, it is possible to mount two 6374s on one ronin truck, ying yang configuration. I’ll try to post some pictures in the future.
I wouldn’t bother making a mount for the Avenues, they are a magnesium hanger, both the current production rkp and tkp and much too soft to support this mount. If you do do it, report how long it lasted for me…FOR SCIENCE!! and if you need an example to go from I have one of each in my shop in Sac, I’m not going to send them anywhere though…
What mounts do you have available for 5055 motors dual drive? The mount on the right can be used without idlers right?
X-configuration is a universal motor arm, it fits any 50xx and 63xx motors. The mount on the right (parallel slots) is specific to 50xx or 63xx. The use of idlers is optional and the slots are there unless you request not to be included.
Which method to tighten a belt creates less drag.
Tighten the belt tension by moving the motor along the two parallel slots?
Tighten the belt tension by using the idlers?
how much for 2 sets for caliber ii to canada?
Not quite sure about the question, the benefit of idlers is preventing tooth skipping. Both idlers and parallel slots serve as belt tensioning. I suppose if you use the parallel slots arm without the idlers would give the system less drag as oppose to the xconf. arm with the idlers.
Hey marcmt88,
I would like to buy two sets of these please! For the Banggood 5065 motors on the TorqueBoards 218mm Trucks. How do I place an order?
-Alex
Evolve GT motor mounts
Left - Inside, under deck Right - Rear, outside mounts
Just want to say huge thanks to @marcmt88 for some custom made motor mounts. I wanted a custom center to center distance that was shorter than what he made before. He said no problem.
The quality is really nice, the vibration finish is a nice touch and the aluminum grade is quite hard! Also international shipping only took 7 days to Hong Kong.
My setup is 97mm wheels, 39t / 20t pulleys, 300mmX15 belt, TB218 trucks with CTC of 72mm. Some people say that this will not work with the idler pulley as head of the bolt will behind or touching the wheel. In my case it works as there is space between the belt and the wheel. 3D printed pulleys. And with TB218’s you have a lot of room to play around.
The only issue I had was with the belts I had on hand I could not get it to work with the idler. I had some smaller bearings #625. 16mm diameter. This allowed it to work with a 300mm belt.
My old motor mounts where hand made by me with a 3D printed clamp. They worked fine but the clamp would crack after some time and it was a huge pain to replace it.
Can 2 6374s be both mounted outside side-by-side using these mounts?
Depends on trucks and thickness of pulleys. I have tb 218mm trucks with enertion 12mm pulleys using these mounts and dual 6374 motors.
How about if used with the GT Evolve trucks + AT setup?
True 6374 motors (not Turnigy 6374s) can fit side-by-side on tb218 and evolve GT.
