Edit: dunno how to fix sideways pictures. Just tilt your head lol
I made this about a month ago and I’m just now getting around to making a thread. I already had two kickass boards; a dual 6374 on 12s and a build from @longhairedboy but I wanted something more portable. I knew about what I wanted, but I got some inspiration from @Randyc1 about the deck and grip job. It’s a modified funbox deck that I refinished. The enclosure is 1/8" abs that I vac formed. It has a 12s2p battery from @oriol360 and I have to say that battery is great. It’s super light and I still get 12-15 miles off of it. Top speed is 30-31 in good conditions with a full battery. It’ll do 27 all day long though. It weighs 15 pounds. The motor is a @torqueboards 190kv 6374. Pretty sure one of the magnets is loose but it’s not getting any worse so… I have seen some other younger builders state their age, so I guess I’ll say that I was 13 when I built this.
Pics:
@DanSkates@moon For the stain I mixed minwax red oak 215 and ebony 2718, and I used a clear gloss polyurethane finish. I did three coats, sanding 400 grit after the first, 0000 steel wool after the second, and not sanding after the third.
How heavy are you and how did it to on hills? I’m looking to build a set up with 12s2p and a 6374 190kv for a college cruiser. What gearing did you use? Sweet build btw
I weigh about 125lbs and the steepest hill i have around me is about 16% grade, and it took me up it at about 1/3 charge, not just with a full battery, which I deem pretty good. I used a 16/40 gearing on 97mm abecs, which gives me good torque and about ~30mph.
