Change of plan. Dual escapes a little too big.
Did you use heat conductive glue? Nice heatsint! Borrowing that one You’ll need phase & power wire slack in order to open
Just double sided tape to test fit atm. Will be using some thermal adhesive once I finish my battery. Phase wire will be reterminaled to a Amass MR60 plug, which I’ll cut a hole and drill through.
If possible I want to tap m2 holes on the lid so I can use longer m2 screws to bolt the focboxes to the lid with termal paste. Idk if I can get the dimensions of the hole pattern right just with hand tools
How is this thing sealed on this spot?
Not sure. Kinda just wanna swap to piano hinges instead of these cabinet ones to give me more room. That way that edge can also be flush and siliconed.
Atm I just wanna have a working board since my Hummie build is shelved.
I might be wrong but for now it looks like it’s not sealed at all.
The hyperbeast is definitely not gonna be water tight imo. Dust proof at best atm unless i put in a lot of work into sealing this bad boy.
I’d agree, not a rain board. What’s the deal with piano hinges?
This should help.
Practice on scraps first.
What’s up with your hummie board?
This happened.
If the price aint bad imma take one
looking good
Started a build thread since I’ve been posting a lot of pics here.
I will take one deck if you make them still
Was sadly a onetime run You might be able to snag one if it ever comes up for sale by a builder tho
Gotcha they look super clean though… hopefully someone makes something like this again
What? She didn’t end up getting it. She got the haya instead.
I replaced those m4 screws that bolts the hinge onto the lid with pop rivots. Highly recommend it. All 8 threaded holes were stripped after 2 weeks.
