you would need the Vesc6 .hex file, maybe @linsus has one (I only got 4.XX HW)
(easier to follow vedders instructions if you have a linux machine)
Youâll need a discoverboard or ST-programmer if you want to upload a new bootloader. Youâre sâposed to be able to use the functioning vesc to fix the bricked one, I havnât tried this yet tho. Maybe @trampa can assist you
We tried using the working one to flash the bricked one thanks to Black Magic Probe tool (SWD prog in VESC Tool). However, no luck to discover the bricked VESC microcontroller. (CLK, IO and GND connected). Next move : STLink
Hopefully u got a spare MCU so you can just do a swap
Hopefully, we wonât need to go that far ! Anyway, there is seriously something to do. Bricking a VESC just because a bluetooth connection wasnât reliable enough is pretty scary !
This is really not eh first time I see that happening (I had the same with old Metr module and cheap Android phone).
that does sound scary, never had any problems with my small cheap modules
You scare meâŚ
It has always happend when dealing with motor/app conf write. Maybe it lacks of integrity check before sending it into internal registers, doesnt it ?
Now, weâre looking for a stable FW version that Metr app can deal with. @Manu39 was on FW 3.40, and everyhting was perfect. But we needed to move to 3.48+ for the use of COMM_GET_VALUES_SETUP_SELECTIVE.
So any FW version advice from 3.48 would be welcomed !
Havnât done any update since november maybe
Not sure which verision Im running, can check
This happened to me too. Vesc6. I tried changing POS ramp parameter using âexpert settingsâ on metr pro. It would try to write the new parameters but it wonât stick. Then eventually fails. After that my motor would spin so slow and cog badly.
I had to reload ackmaniac fw to clear it. Iâm still using the metr module but using the ack app instead.
What VESC FW ?
does someone have the BOM and schematics? links dont work any more
(I have 2 bare PCBs that I would like to use sometime in the near future)
Thanks
Whatns the brake fix ? Does he has a github repo where I can check it ?
The link is the github. Brake fix was done by deodand. He just merged it w ack FW.
Sorry, I had a (too) quick look and didnât see sources. Whatâs the improvement in your ride feeling ?
AFAIK, Vedder considered to bring @Deodand code improvement into official firmware. But IDK if it has been applied in the end.
The only real difference is the low speed braking. It doesnât lock up. Well what I read here in the forums, vedder has merged this fix into his official fw. Or he may have just made a fix based on deodands fix. Not sure. I havenât seen the code.
I really like ack FW. Just a better linear ride feel for me.
Yes, the deodand brake fix was implemented 3 or 4 iterations before last official firmware
Some user was able to compare data between ack and vedders official fw. Based on his findings, better ride control and better battery consumption.
Iâm gonna have to look for that post. Once I find it, Iâll post it here.
Ok, I found back where it has been discussed with Benjamin :
This has been integrated in official FW since FW 3.48.
