@Kug3lis that sounds like a fantastic ESC your working on! I’ll definitely be ordering a set when you offer them for sale! Do you have an idea / rough estimate about how long it’ll take till you’re finished and ready to sell?
Also, isn’t your design using no drv/dvr chips since they seem to get fried easily from what I understand?
I am surprised that there isn’t any interest in a thicker board routed from the top, like chaka’s. It would be nice to just plugin the cells like hummie is suggesting above.
if it gets any thicker the trucks rub when turning and it starts to feel like youre riding a brick. as it is now it feels like a normal skateboard with nice slight flex
will do 14.3a constant current up to 42v (that’s 600w).
no fan
durable (looking) waterproof enclosure
7 year warranty
reputable mfg
designed for street lights or crazy stuff like that
A suffix means adjustable – there’s a pot for volts and a pot for amps.
But,
cc/cv supply, not charger, so no termination
no voltage display
there’s no model that can do 10s and 12s
A bit less power and not as big voltage range, but a lot less likely to die on you or do crazy stuff. $140 at qty:10 or above hmm… GB? Unfortunately, this series doesn’t have a model that can do 10s and 12s.
Ummm 10s6p not a flat pack then right? He doesn’t have a enclosure posted for Hummie decks that are not flat packs. At least not that I know of. I’m probably gonna get a 10s6p as well
Yeah you’re right about that. I recall him mentioning to go with altar wedge or the other lomier burst(not sure if i spelled that right) for those bigger packs. Hoping @Hummie can put an enclosure with my order as well so it would be a perfect fit for a double stack!
I modified a set of old base plates and mounted them on top of my drop through deck with longer bolts and it worked a treat. looked like a drop through truck from the top with the truck mounted below.
Just cut off the raised section for the bushings and it acts like a double clamp. Took a little while with the grinder and sander then a quick coat of satin black and it looked pro. Depending on the truck you will get a gap that you could conceivably use for switches etc. I’ve also done a similar thing with a baseplate to create a trailer hitch using the bushings as a swivel. tows a deck with a back truck on and a milk crate which holds exactly one carton of beer. Working on a quick release version now. Will post pics when its done.
on the bright side, 3 weeks gives some of us more time to get all the other parts together in time for the deck excited for them squeeze packs @hummie has got planned!
yea 3 weeks i imagine for sure theyll be here. and europe a day or two earlier.
ill do 110$ going forward. friend and fam. [email protected] and then wait till they show and I’ll post here and we can figure the addresss and details by pm
I’m in no rush, have most my parts. At least all the expensive ones. waiting on my battery to be built. Might try picking up a pair of six-shooters before it gets here but the 107mm superflys will be great if not.
