Yup 50 cells + 2* focboxes and a small bms like supower will fit without any mods
10s5p 2x focboxes bestec 80 amp bms. 460mm+65+80
what about antispark switch? bluetooth module, receiver, I canāt imagine fitting 50 cells with everything required?
nice! hows the wheelbite?
Xt90s , nRF24L01 module. Very thin. Bluetooth module will probably fit. Not using one anyway. psychos arc v2ā¦ I havenāt put it together yet, but should fit. Enclosure got a upper level/slot for switches and voltmeter etc.
No wheelbite with tb 218. Caliber 2 10" you get some bite. But should be fixable if you sand it down a bit. 6" wheels
itāll be the same exact board as before but with the slightly wider cutout and the inner carbon layer dropped internally for greater strength/stiffness. and no blue dots.
Yeah was wondering what those blue dots was?
call it art
Damn. Was hoping for Walters meth
Iām also offering this board with a much bigger cutout thatās 16mm deep and 40" x 10"!
That canāt be right? The deck itself is 40"*10 right?
So you get a big box of air! The new Hummie Airride - it also comes for only 100$ shipped
yup couldnāt hold that joke down
@Jebe I donāt know shipping to australiaās cost. I have to go to the po today and will see
Ouh snap
First day commuting with the deck. Ride is super stable and smooth! Thanks again for making this happen @Hummie
buy 5 more only reason I want to do this again is because I want that 145mm cutout so I can use my copper 18650 compression connection battery
Money is kinda tight right now. But I wanna try routing a 1/4in pocket between the enclosure and trucks so I can mount the VESCS there. That way I can use the entire main area for a bigger battery. If I fuck that up Iāll have to get another one
