As you can see in the thread I had to replace my Mosfet drivers and Mosfets and had no problem since. The first time I accidentally bridged some connections on the bottom next to the soldered wire with a bad soldering job.
Maybe you did the same?
Ah ok I seeā¦ I look after them later today and try a new battery, if everything looks good. Thx
So from looking at the picture you posted it looks like you got some nice welds. What made the difference?
Yep! Was the battery! Just went and bought a 95 Ah 710A big battery and everything works perfectly fine! Iām welding with 11 mS now
what kind of wire are you using? i got some fat wire but it is very stiff and i cant pull it through the transformer
8awg. Works good, but gets warm after a few welds. So Iād take 2 8awg parallel.
just leave this here for other people to find: Arduino Spotwelder from KƤptĀ“n Balu:
@acido Maybe build your own? There are plenty of diy options out there. Some good info in this thread too.
