You can keep them for a few months or even longer at 3.7-4.0 V. I left mine at the Voltage they came as, from the factory for two months with no problems. If your cells are at close to full charge I would discharge them to storage levels after two weeks of no use.
When you buy them, they will come at 3.7-3.8 per cell for shipping. When you get them, you need to check the voltage of each cell individually. It is possible to get a battery with one or more cells that are under minimum voltage. It happened to me twice buying zippy lipos. If you get a battery like that, the seller should replace the pack.
There is plenty of usefull stuff here, thanks a lot @Namasaki. IĀ“m on my first build and would like to get the wiring confirmed.
My batteries and balance wires are a bit different. I will put 5x 2S2P in series to get 10S. IĀ“m confused with the balance wires, the batterie has one more connection in the middle, what is it?
Also my 10S BMS has 11 wires, one is black. IĀ“m not 100% sure where it goes. Is it right to have it on the negative of the first batterie? All the other negatives are not connected, right?
Would be very appreciated if someone can have a look and confirm, that it is right like that. Thanks a lot.
Three more questions:
- Does I have to disconnect the loop key while charging?
- The BMS doesnĀ“t have a on/off switch, will it drain the batteries over time? Should I place the loop key somewhere else?
- Does I need a inline fuse somewhere or is it enough to have overcurrent protection in the BMS
Iām at work now but will get back to you as soon as I can
No worries, thank you very much anyway.
The orientation of your balance wires and main wires is correct. Removing the loop key during charge cycle will stop the esc from powering on and is not a bad idea. Iām not familiar with your BMS or the amount of drain it will impose on your battery. You could put a 2nd loop key on the battery negative main and run a jumper from the B- pad to pin 0 of the balance socket if the the 2 are not already connected in the PCB. Then you could disconnect the bms by removing the key.
Awesome, thank you very much for your time. What do you mean with ārun a jumper from the B- pad to pin 0 of the balance socketā? Pin 0 is the black one on right? With jumper do you mean to connect them? What is it doing if I connect it? Maybe instead of the Loop Key I could just pull the main negative out of the battery if I wanna store it for a longer period of time.
Like this (added green wire)?:
Yes, Like that. That way you can stop all current flow through the bms when you pull the key. Now I canāt say for sure that the jumper is necessary. It depends if there is continuity between the B- pad and pin 0 through the pcb. It may be that pin 0 is an optional ground used when bypassing the bms for discharge so that you wouldnāt have to use the B- pad at all.
You could (with all battery wires disconnected) test for continuity between the B- pad and pin 0 with a multimeter. If the meter beeps then they are on the same ground and you can omit the jumper.
Thank you very much. I will do all the wiring and see how it goes.
Hey. @Namasaki If I was to buy this HCX-D223V1 BMS in 13S variant. but use it only in 12S, would that be a problem?
Thatās why Iām asking: https://www.alibaba.com/product-detail/battery-management-system-bms-for-e_60292861212.html?spm=a2700.7724838.2017115.23.3471310aR3w4WU
I wanted to use these in 12S
Yes, it would be a problem. These bmsās are specific so you have to get a 12s bms for 12s battery
Thanks a lot for a clarification @Namasaki, now Iām tempted to go all out with 16s but it sound ridiculusā¦ Not sure if Iād ever need that and How Iād charge it. Plus I have to buy two and have no clue about what to do with another BMS, electrify a bike?
I have one more question, do you know of any other way or source of purchasing that particular type of BMS in 12S config? Or is Alibaba my best shot and I should just stay patient and wait?
You can order directly from Bestech or create a thread in the items wanted category to see if there is one available from a forum member
Thanks a lot.
Just a heads up, bestech arent answering emailsā¦ i must have tried 5 or 6 times over the past couple of weeks, from different email acounts, and to their info@ and sales@ accounts = nothing
If anybody has any ideas on how to get them that would be great
Try http://litechpower.com/BMS/ itās a little longer ship time but there is no minimum qty required.
Bestech and litech are the same company.
Thanks man!
Hi, Iāve got one more question. Is this BMS: http://litechpower.com/product-detail/HCX-D596LF12S.html
going to work fine with a pair of these: https://www.rcdetails.info/en/details/11204
also is it possible to receive guidance on how to connect it to vesc6 and BMS
There is plenty of information and guidance in this thread. Please read through this entire thread and if thereās something you donāt understand, we are here to answer your questions.
