I’ve been lurking for a while and read quite a bit but still struggling to make sense of the electronics side of my e-build. Parts I currently have:
Caliber II 50 trucks
Caliber motor mount
41" longboard deck
Abec clone wheels (83mm)
I’ve now need to focus on the electronics / gearing side of things. Could some assist with me the following requirements?:
I weigh 100kg
Want to run single motor with ability to climb 25% hills
Top speed not too important, a max of around 20mph would be nice
10 mile battery radius would be ideal
Ability to ‘plug into the board’ to charge would be good
With me being quite a large guy (6ft 4") I’m not sure if this is possible? Could someone point me in the direction of what electronics / battery / gearing I would need to achieve the above?
Ideally would like an easy solution for the battery’s rather than having to ‘build my own’ as I’ve seen others do. I’m based in the UK but willing to buy from abroad.
I would suggest going with Focbox, at least 10s4p 30q battery, 15or16/40or44T gearing, 15mm htd5m belts, and at least 6374 motor.
The is big because you need enough oomph (amps) for your weight and it will give you more range
