probably. PLA glass tmp is much lower than PETG.
Have you tried PC yet?
Nope. i’m kinda on break on 3d printing. only use when I need it. also kinda burnout on this proj. there’s something else i have in mind but idk when I will have time to do it.
no “consumer” level printers can do PC so was woundering if your printer could do it
with a full metal hot end, enclosure, maybe. haven’t looked into whats difficult about PC.
this is the hard part about printing PC, enclosures is a must i believe and those are not in consumer printers, but even if a consumer printer has a enclosure. chances are that the hot end and heated bed wont reach a temp high enough.
@Winfly could you reply to my PM or am I going about things the wrong way to try to make an order to fit a HAYA?
Whoops I read it and forgot.
@Winfly can you post/pm/pineapple me the HAYA 21700 files?
Also, do any of these take heat shrink around the batt? Didn’t see it in the description on thingi so I presume noy
Thank-yew
I only have the 20700 holders atm. @neiru37 finally finished building his 12s4p sanyo pack. I can go home and modify it for 21700. But please print and test them before building the whole pack.
Counting on @RedBaron for printing. We’ll let ya know. Give us the thinnest walls you can that will still work, I think total depth is 23mm. Definitely no room to widen the diameter with thick wall heatshrink.
Need 21700 haha.
Give me the 18650 files in a form that aren’t STL and I’ll make HAYA 21700 modules for everybody
The HAYA is only 22mm deep so you are gonna need the 20700 I made for @neiru37. I’ll post them up tonight.
lmao yer either high as fuck or super fuckin busy and stressed. I’ll presume the latter
Either way - I’m going to make this HAYA HB83 Shortboard run 21700’s in a compression style holder. Just like I’m going to make it run 110 wheels. If I have to route out a bit of the deck myself for some more depth to accomodate, I will. I just want to use the base design of your holders
Lmao, I’ll do it later tonight.
To be fair my Haya is a v1 prototype so dimensions could have changed.
Oh, I guess I haven’t posted in this actual thread - but I know from PM I’ve mentioned to him it’s the new stuff haha.
