Today on another group ride I took the effort to read temps again. And with some more aggressive riding the throttling was worse. One motor is getting hot way faster than the other one.
At this point it was slower than a meepo and Ownboard again, torque wise not speed. I was making short sprints to achieve these temps. (that’s the worst case scenario)
I wonder how throttling will be when it’s 25 celsius outside. If the one motor wouldn’t heat up as fast as it does throttling might be less as the ‘good’ motor has so much to compensate it also throttles up faster.
If you don’t take short sprints the board performs good. Not in a drag race, it would need to be pretty cool to be relevant/win, inclines might a problem too havn’t tested
hi
maybe someone can help me here , i have the 2.1 hub motor from enertion and the number from them are not the same ,is it normal to have this difference between them ?
Thanks
You have to roll motors as hard as you can, single time in forward direction to get the equal values.
Also, Make sure the bullet connector configuration is identical for both motors.
I fixed this issue on my Raptor recently, I think this applies to DIY setup as you are using Enertion Drive kit
Look at your hall sensor icon. To the right of the picture, it only has two. The left has 6. Bad hall sensor? This is just my assumption.
Mine exhibited only one sensor on my one motor. Weird thing is it passed motor detection and all but I had trouble stabbing the trigger. It cogged badly.
My inquiring mind wants to know.
Maybe the expert enertion dudes could verify this.
Guys, I am experiencing some strange behavior with the unity under full throttle.
My setup is dual maytech 190kv 6355 sensorless motors.
I know it’s normal for sensorless motors to stutter at startup, but in my case even after a few pushes, it sutters once I punch the throttle.
So far it didn’t happen when I eased into the throttle, slowly accelerating.
In one instance it even ran for a bit and then it stuttered with a bit of speed already. Making it super dangerous since I was leaning forward and not expecting it at all.
