Hello,
i want to change the days my current set up to a foc box unity… but i still have to think about the erpm limit… with vesc 4.xx i was able to set 60.000, so does unity work? or how does it work? May not kill the box immediately.
I built in a 12s Lipo battery and 2 motors with 2000kv each ( 3,2 kW )
Would like to run every motor with 70-80A each…
Power of the problem concerning the erpm limit?
@boostem You will still need a BMS, you can use a charge-only bms which should be smaller.
@Flo091 60 kerpm is easily handled by the unity. We have tested up to 130 kerpm without any failure. The unity will give your board the power it needs.
I don’t make them sry, I just let @3dservisas use my Unitys to make it so I got a test example for it. I think they will do a groupe buy later but I’m not sure.
It’s realy nice I will use them in my 2wd boards that use 120A battery, the temperatures is lower for sure, will do a real compare with and without after I done my surgery for my shoulder next week and can stand on the board again…
