Yeah, me too, I’m really hoping the gold looks nice when it"s all said and done. Thanks for the encouragement.
The look of the board is going to be beautiful, I see some Trampa, some Raptor 2 and some RedEmber mixed in one deck
IDK how thick are the bamboo veneers but anyway I would be afraid the will crack int the angled are of mold Maybe you could round the edges little?
Do you plan on using vacuum?
Where did you get the basalt fabric? I was looking for some and I didnt find any…
Looking good!! The new tesseract is also using basalt.
I was worried about them breaking as well so I did a dry run with one of the planks of bamboo to see if it could handle that type of angle. Looks like all I need is more clamps.
Nope, just lamination
I found some on this site https://basalt-fabric.com/ but you have to contact them to figure out prices. They have a very large selection of different weaves of fabric, and they have a resin / fabric coating that keeps the fabric from darkening or turning green like the Trampa board.
So to go along with this board I quickly threw together a list of electronics. I know this is going to be far from the final draft but I just wanted to show you guys where I’m at. My goal is to go offroad and on hills without a problem. Help will be appreciated.
- Motor(s) x2
• Racerstar 5065 BRH5065 200KV 6-12S Brushless Motor Red Without Gear For Balancing Scooter ($56)
- Pulleys & belts x2
• Chain Drive (40/10? or 4:1) ($36.49 ish) http://kevindark.co.uk/Blog/Read/7 https://www.technobotsonline.com/6mm-steel-chain-sprockets.html
- Mounts x2
• Turnigy Skateboard Conversion Kit Spare Parts - Motor Mount ($10 each)
- Wheels x4
• 200x50 - 8" pneumatic tire w/5 spoke rim and 9.5mm I.D. bearings ($15 each) http://www.yakresearch.com/product_p/200x50pneumatic.htm
- Trucks x2
• 15" Mountainboard Truck, 9.5mm axle ($16)
- ESC x2
• Still looking
- **Battery x2, **
• Still looking
- Charger x1
• IMAX B6 50W 5A Charger/Discharger 1-6 Cells (GENUINE) ($29)
- Remote x1
• XCSOURCE 2.4GHz Radio Transmitter Remote Controller + 4 Channel Splash Proof Receiver + Binding Plug for Electric Skateboard OS917 ($25)
https://www.amazon.com/dp/B073GX83NH?tag=mike0939-20
- Enclosure
• Still looking, maybe custome
Ok just a few things, I don’t think those mounts will fit on to the trucks without lots of modification. I would also look at some other builds and see what trucks/ wheels they are using as those ones I’ve never seen and the wheels don’t look like they would have much grip on off road. That charger is also no good unless you have a 6s battery or less and don’t mind waiting 2h+ for charging.
Apart from that the motors, pulleys and remote are all good, although bigger motors might be needed depending on weight and sort of off-roading you’ll be doing
Thanks, I relized I’m gonna have to do alot more research like battery types, motor Kv, esc’s, and I’m also going to work on organizeing this topic a little more.
Do you have an idea of what your budget is?
In the range of $600 to $1,000 if not less, I don’t want to go to overboard but also want a quality(ish) board.
Update
- Motor(s) x2
• ELECTRIC SKATEBOARD MOTOR 6355 190KV
products/electric-skateboard-motor-6355-190kv
- Mounts x2
• Still Looking
- Wheels x4
• Still Looking
- Trucks x2
• Still Looking
- ESC x2
• ELECTRONIC SPEED CONTROLLER
products/torque-esc-bldc-electronic-speed-controller
- **Battery x2, **
• Still looking
- Charger x1
• Still looking
- Remote x1
- Enclosure
I would recommend getting focboxs just because they would be more reliable on an off-road board. Btw if your on a tight budget Keda 195kv motors are a great steal, much cheaper than those of you listed and very reliable, well mine have been. They have taken a considerable knock at about 30km/h into a concrete pillar with only a scratch.
They have two versions 6364 and 6356 (listed as 5663 for some reason) I have used both
Update 2
- Motor(s) x2
• KEDA 56-63 195KV Brushless Outrunner 6S 1500W ($42)
• Chain Drive (50T/10T or 5:1) ($40 ish) http://kevindark.co.uk/Blog/Read/7 https://www.technobotsonline.com/6mm-steel-chain-sprockets.html
- Mounts x2
• Still Looking, probably custom
- Wheels x4
• 13018 - Complete 7" Knobby Wheel ($20)
https://www.mbs.com/parts/13018-complete-7-knobby-wheel-1
- Trucks x2
• 12008 - MBS ATS Truck ($30)
https://www.mbs.com/parts/12008-mbs-ats-truck-1
- ESC x2
• FOCBOX Electric Skateboard Motor Controller ($150)
- Battery x5
• ZIPPY Flightmax 5000mAh 2S1P 30C hardcase pack ($25)
- BMS x1
• Bestech BMS ($48)
https://buildkitboards.com/products/bestech-bms?variant=7201537654814
- Remote x1
- Enclosure
Might want to re think that battery. It is a 2s battery which is far below what was offered as the common range of 6s. I suspect you might be wanting to run them in series which will still only get you 4s. That motor is appropriate for 6s-10s in my opinion.
He put ×5 which I assume means 5 2s batteries in series to make 10s
I was going to buy 5 of them
and put them in series to try and mimic this build by @Namasaki, I guess I should’ve specifide that, my bad. And I think by doing this It’ll hopefully work.
Exactly
DOH! I read that as 2x lol prob. because of the 2s… Makes sense now!
Much better looking list of parts now make, should make for a damn good board
@J.Biggs I would not recommend 5ah 30c packs even for a street board let alone a EMTB.
I would recommend no less that 60C and preferably something closer to 90c or even 100c
I was going to use the ones in your build but they were out of stock when I checked. Thanks for the advice. I wasn’t to sure if it was gonna work.
