Guys it’s very hard to convert mini to be smaller and both trigger and thumb wheel. Is it a big deal to have it both in one enclosure? If they were two separate versions?
It’s not smaller…it’s thiner in the upper part. Will fit 18650 and some electronics. I’ll make some small improvements but it’s almost done. In my opinion can’t do more with the mini (without serious internal redesign) because the way it’s build inside.
What do you think?
Looks great, glad to see someone doing this. The only thing I better would be if you could reverse the position of the trigger and make it a thumb trigger with a new nub.
My first atempt was to make it universal that you could choose thumb or trigger,. I have spend so much time on this and just could not make it happen. I had a version with electronics on the bottom. It looked ok but was’t confortable to hold. After that I decided that it has to be separate so if there will be a interest in thumb version i’ll give it a try.
I can see the difficulty, the remote would have to be at least 20mm longer to make the electronics and the cell fit. Ill think about it and see if I can come up with anything. Ill PM you if I do. Good job on this though, there’s a lot of Mini-Remotes out there. I actually stopped using them because I like the thumb throttles a lot more, but that wheel was a pain and even after removing it there was still some comfort issues. Looks like you solved those.
I’m with @mmaner on this one too. I loved my gt2b with chosen mod until I got a nano-x. I ended up selling my mini remote for that reason. I’d love to have a thumb throttle mod for the mini available again.
I was going to do this, but I want to use li-ion cells and a few other mods. Have some crazy ideas
I just need this remote enclosure in a 3d file, then I know I can work with it from there. I dn’t know how to get all the other holes and what not lines up correctly in fusion 360.
I think a trigger guard would be more in order LoL. First time I ever used a mini remote I was trying to open the overhead door upon my return, and bumped the trigger. Ate street.
