Charge current is only 15A Question My setting for my battery min is 15 2 motor This mean if I break really hard I have 30A come to my battery I believe this bms will not work correct ???
You will be charging trough the discharge/load port (as you should), this will be no problem at all!
I just read the thread about the metr.pro upgrade, just awesome progress!
But now, the VESC is kind of the CAN master when using metr.pro and need to be powered on before the communication gets active. I prefer not having my VESCs energized for an hour or longer during charge.
Does the D.B.MS forward CAN data? if so I would be able to connect the metr.pro to the BMS serial port instead of to the VESC. This would open up some possibilities:
- The VESC would not have to be powered-on to monitor the charge process or battery state.
- Metr.pro would be able to send push messages when charge is done or if there is an issue
- With push-2-start I would be able to check my battery state before rolling off
- At some point the BMS could also store VESC logging to the SDcard.
So I might have missed it but what is the current amp capacity for discharge of the unit?
So I am waiting for my DieBie to arrive. What is the recommended charger for a 12s setup? What are you guys using.
If I have read correct info. It is recommended that charger is about 3V higher than the full charged voltage of battery.
https://www.meanwell.com/productPdf.aspx?i=327
https://eu.mouser.com/ProductDetail/MEAN-WELL/HLG-480H-48A?qs=u4fy%2FsgLU9PVn6yM5LRg%2bg%3D%3D
Ive read that these could be good for the DieBieMS. Could be useful fo you
So what is the status of the phone app? Is there one for IOS?
metr.pro works like a charm, not for configuration though
damnz, those meanwell’s are expensive
for my 10S setup I use an aliexpress power supply, 42v 3A, I paid something in the range of 25€ just search for “10s lithium charger”
Right, I’ve just bookmarked those because @JTAG had mentioned them somewhere.
Additionally, I believe you need an extra 3v on top of your nominal voltage for your charger, so having the adjustable Voltage and Amperage so those are nice for that flexibility
What do you mean? You are not able to configure VESC via metr app?
Metr.pro is designed for VESC and works great for logging and configuration!
They are currently integrating DieBieMS features (state of charge with fancy animation), no configuration page for DBMS (jet?) you can still do so via the terminal and CAN fwd (ID:10) in the app.
@JTAG didn’t see it anywhere, but would this work with Hobbywing Max6 ESCs and off the shelf Turnigy cell packs? Do I need to have a Vedder based ESC?
Any update on this project?! Looks like it would be amazing for some of us
What about simple PWM?
I am not really familiar with switching losses, heating and stuff. But in my understanding a buck converter is only a PWM switch with additional smoothing by caps and coil. And for buck converters efficiency rises for low voltage differences (vin vs vout). So if I am right, the losses at high dutycycle switching should be small and from ~55V to 36V you are always above 65% duty, for Lipos even above 80% duty. And even if there is some heating, you could always regulate the charge current down according to the temperature of the closest NTC. So you do not have to have a CC/CV powersupply but a CV is sufficient (like the cheap ledstrip powersupplys)
So what do you think, could a simple software 40kHz PWM regulate the input current?
Hey Guys,
I need you help. @JTAG
Just attached the DieBieMS to my 2 x 12s5p == 12s10p. The balance cables and PACK +/- are connected.
- DieBieMS does power up. HW V0.7
- DieBieMS-Tools can connect to the MS states FW 0.16
- FW Upload does work.
- But after reboot - it is still 0.16
- Can NOT read / NOT write values with the DieBieMS-Tool
- only Terminal commands.
- Strange “State of charge” - 1.5% - at 12s with 48.97V it should be above 90%
What am I doing wrong?
Please find all data below.
------- BMS Info ------- Firmware: V0.16 Hardware: V0.3 Name : DieBieMS UUID: 33 00 3E 00 10 57 34 56 36 30 33 20 ------- End BMS Info -------
----- Cell voltages ----- Cell voltage 0 : 4.088V Cell voltage 1 : 4.089V Cell voltage 2 : 4.080V Cell voltage 3 : 4.089V Cell voltage 4 : 4.089V Cell voltage 5 : 4.089V Cell voltage 6 : 4.089V Cell voltage 7 : 4.088V Cell voltage 8 : 4.089V Cell voltage 9 : 4.089V Cell voltage10 : 4.089V Cell voltage11 : 4.083V Cell voltage high : 4.089V Cell voltage low : 4.080V Cell voltage average : 4.088V Cell voltage mismatch : 0.009V ----- End Cell voltages -----
-----Battery Pack Status----- Pack voltage : 48.97V Pack current : 0.02A State of charge : 1.4% Remaining capacity : 0.57Ah Operational state : External (USB or CAN) Load voltage : 0.00V Cell voltage high : 4.089V Cell voltage low : 4.082V Cell voltage average : 4.088V Cell voltage mismatch : 0.008V Discharge enabled : False Charge enabled : False —End Battery Pack Status—
— BMS Configuration — NoOfCells : 12 batteryCapacity : 41.00Ah cellHardUnderVoltage : 3.400V cellHardOverVoltage : 4.250V cellSoftUnderVoltage : 3.300V cellSoftOverVoltage : 4.250V cellBalanceStart : 4.100V cellBalanceDiffThreshold : 0.010V CAN ID : 10 — End BMS Configuration —
OK @JTAG - read the whole thread again and found the part where you describe the bootloader_jump command.
Now it says v0.21 in the DieBieMS-Tool - but the LCD states v0.17 at boot.
Is this normal?
Hi guys!
Sorry for the lack of response from me lately I have been very busy. But also busy on adding new features to the BMS and the interface. The most important thing I am working on is a self test feature to test the BMS after production and changing the hardware to add test pads for a test fixture.
I will soon take time to answer all unanswered questions soon!
And for the last question, I am sorry that might indeed be a bug . I still have to automate incrementing the firmware version on every place in the firmware automatically.
DieBieMS is now managing 12s10p of 20700B.
Wow - this is just the coolest BMS around! Thanks @JTAG from Hamburg.
