What’s your ideal budget and what is the shape of your battery?
@spesh I just googled Hummie deck and a billion different things came up but the companies website. Do you have a link so I can check out the styles?
@skunk I don’t want to spend a lot. Probably £100 GBP? The board is going to get trashed because I use it daily. I’m not looking for anything super light. The DB freeride seemed like a good board and it’s served its purpose especially as I only paid £30 for it!
My battery is going to be long and thin. I’m currently using 3 Zippy Flightmax 5000mah 3s1p batteries. The current enclosure is about 30mm high (external).
The hummie deck is made by a member of the fourm. I have one. Very nice.
@skunk so that deck looks like it’s got slots for the batteries? That’s pretty cool! Are you able to post pictures of your board so I can see the underside?
Just search for “wood and carbon deck” here on the forum. There’s 2 threads about it. One in us and one uk. Shitload of pics. Hummie is not a company. He’s a member on this forum
https://www.electric-skateboard.builders/t/new-wood-carbon-decks-group-buy-round-3-110-shipped-us/43245?u=skunk Unfortunately I’m at work and don’t actually have a whole lot of pictures on my phone but there’s the original thread from the USA Group buy. And if you type in hummie deck in the fourm search, there’s quite a few builds using that deck on here
£100 for the deck and £45 for the simple enclosure. Something like this. (Top board)
It’s also good to bear in mind that these decks have more layers than most decks I’ve ever owned. They’re pretty tough and have a beautiful carbon fiber top
I literally just messaged you on Instagram
Are you able to post pictures of the board with the wires coming out, on/off button, etc etc etc. I also need it to fit my heat sink plate. Will that work?
I’m looking through the group buy thread now @Skunk
I think going through the USA Group by you’re going to see more pictures of the deck with psychotillers enclosure on it. You probably see more with BigBen’s enclosure on it via the EU Group by
While it is a little bit above what you wanted to spend you’re not buying a longboard and adapting it to esk8. This deck is made for us.
So I’m looking through these threads and I love the deck but my concern is the enclosures. I love the fact that it’s meant to be super slim and beautiful but I feel that slimness is removing some functionality. For example, I can’t see where people are putting their on/off switch, battery percentage reader and charge ports?
I’d like those things to be on the enclosure aswell. And again, I’ve not seen anyone using a heat sink plate with the enclosure?
Maybe this isn’t the right deck for me. I won’t be sold unless I can have all the above.
Any ideas Master (@bigben)?
H I’ve been using push to start and app for voltage display so done away with 2 of the need for holes. I stuck a hole in the side for charge port. There is another version of the enclosure that covers the wires. The heat sink plate should be able to be cut through the fibreglass enclosure and bonded to it. Some switches and meters are integrated into a cover for the dropthrough holes. @amazingdave is doing something like that here.
I saw on the group buy thread that you do a double stack enclosure. What’s the depth of that and what’s the depth of the deck cutout?
I’d like to keep the bits and bobs I’ve got because I bought them a few weeks ago. Seems silly to get rid of them already!
My thinking is having the switch, screen and charge port on the bottom of the deck facing the ground? Similar to the Enertion boards.
Ref Instagram: When you’ve done your inventory check can you let me know if you’ve got them in stock? Am I right in saying there’s 2 lengths? It looks like it based on the pictures above!
Cheers, Daniel
Here’s an example of tillers enclosure that someone put a heatsink on. Although I’m sure you could do the same thing with Big Bender enclosure. Both look great
Big Bend???
Lol. Damn talk to text.
I know what you mean spunk.
Look i fixed it lol
actual tears now.
