30 feet of pure nickel strip, I also put a small piece in a hydrogen peroxide/vinegar solution and this is what it looked like after an hour.
I also got another set of old enertion stock of 36t gears so I can run my awd set up on 107s if I feel like it.
Also my fish paper came in
And I got some parallel connectors and some reciever connectors.
And Iām not going to use antispark switch since they are unreliable with high powered set ups so I got this loop key from @torqueboards not sure if Iāll use it but itās an option.
Iām still waiting on the Boss Spot welder, the lipo, charger and my 4th focbox are all coming in on Monday.
So I go to set up my focboxes and one failed during motor detection I opened her up and I dont see any signs of physical damage but I saw it had the plastic film on the thermal pad
This was the only one with the film on it but I purchased this focbox second hand do you think enertion will help?
My 4th Focbox came inā¦ wtf these are tiny bullet connectors and an xt60 connector? I guess xt60 would be enough since a focbox cant handle 60amps current anyway lol
Also my spot welder came in
There is no fan connector on my spot welder should I just solder the fan wires to the board?
So Iām having trouble running my set up in sensored mode, I had the same issue before with my old vesc x but me thinking hey I have new focboxs and new motors so it should work right? Nope same problem it passes motor detection fine but when I try to accelerate it just cogs and dosnt move. Iām using the TB sensor wire so Iām thinking the sensor wire from TB is not wired correctly for the focbox? Itās the only thing that has stayed the same in the set up. I have to run sensorless for my board to work properly. Anyone know whatās going on.
Ran the board 2wd on the 60t pullies and I warble to briefly achieve 36.5mph with a nice tuck.
Also here I am comparing the 60t pullies to the 42t theres a huge difference.
@psychotiller how fast has any of your customers been on the 6 shooters? With 4wd and 42t pulley my top speed would be around 50mph can these tires handle those speeds?
There is little question that the six shooters are good to go over 40mph minimum. Also clear that @psychotiller awd is most terrifying on the way up to 40mph (beast torque) than cruising over 40mph once attained. Also clear is the street luge and his secret sauce will be a rocket to watch(out for).
Anyway, that reminds me I wanted to pull back out my sixshooters and try them on carvons. I have the TD adaptor but will that also work on the SD and XL? Canāt rememvwr which was ABEC vs clone vs OK to try anyway haha
