Okay I can def fit a 12s8p with 4wd np, If the enclosure and the deck were the Same width front to back I could have made a 10p but the back end of the deck is too narrow.
Wow! Crazy battery! Good luck man!
Hey @ me when you finish it and hit me up with a link
The build sounds awesome, How do you have the money for it
My current build on my evo.
Nice Iām finishing the battery soon after that itās smooth sailing should just come together. I had to use a difference battery config cause I needed the extra space for 4 Focbox
4wd?! why thoā¦
why = heās like 8 1/2 feet tall
Lol itās in the title of the thread this has been planned for months.
I want 4wd cause Iām big and heavy and Iām a speed junkie.
Should be able to get 50mph+ on this set up.
Havenāt posted in a while, but I have made some progress, I have completed the battery, I was pinning the wires for the BMS and I ran out of pins so Iām stuck here for now.
Was test fitting the battery and it looks great but itās going to be very tight for a 4wd set up
I do have some verticle room in the enclosure because itās a double stack enclosure so I need to think of some ways to mount everything else in there safely.
Just finished putter her together and took her for a short ride.and holy crap I didnāt expect torque to be this intense with this gearing ratio but the 4wd doesnāt even sweat it.
Im waiting for my Mini sparky thatās why Iām using a loopkey for now and my touch screen from @Wajdi
What a beast. Well done squeezing that lot in there!
Thank you, this build has been in my head prepping every detail for months. I didnāt expect it to be this nice haha.
Btw 4 motors screaming all around you as you fly by is quite the experience you donāt get on normal builds.
I bet. I guess it saves on the times youāre screaming āOutta my way mortalsā
Is this what you got on the calculator???
I got 49mph on the calculator. I was thinking cause the extra 2 motors I could possible break 50
Just read this entire thread start to finish. What a machine you have built there. (Insert multiple praise words here, then repeat)!
Love the attention to detail, and the shear power that thing develops. Iām on my second build now, with similar wheels - not SS but definitely 6" and same tires. Considering the same deck as it happens so interested to know where that enclosure is from, and do they do a single stack, lower profile, version for a 10s5p flat pack?
50mph is too fast for me, but I love seeing builds from people pushing the limits. Well done, itās an awesome board
Edit: found it on eboosted ! Might get one!
The enclosure is made by @Eboosted he originally only sold the single stack version. I asked him yo make me.a double stack and this is it.
You can find it here. https://www.eboardsperu.com
@Deckoz fit a 13s5p in his flat pack enclosure.
Thank you for all the praise. Now Iāll be taking it to the group ride Tuesday letās see how it handles.
That is just frikkin epic. Prolly the best board Iāve seen all year, this and the Lacroix @Sender built.
Thank you Mike that means alot coming from you and your bad ass builds.
