What motors are you going to use? I can measure mine when I come back home.
i want to get access with the stl files thank you !
Dual 6374
Iāll take a look when I am near my CAD computer.
Placed an order on the wheels. Got 4 wheels for 70$, quite good deal IMO.
What tire options are avalible? Stock is ok?
The stock tyres seem good so farā¦ bergmeister tyres should fit these rims too.
Stock is great. Thatās the most used 6" tire on this forum.
canāt wait to get them
Calculated my belt length and going to use a 330mm belt. With 50T I get 6 teeth in mesh and with 60T I get 5 teeth in mesh.
I think I prefer 60T for torque but I wonder if 5 teeth in mesh is enoughā¦
Whatās the belt width? 15 can handle
Iām going to use 12mm cuz thatās what the size I have on my motor pulley. Will probably adjust the stl to 14-15mm instead of 17mm
i can definitly recommend using other bearings for these wheels, rolls alot better than ealier.
Indeed! New bearings roll for 10+ seconds without any riding being done. Good stuff.
got a lil more footage while testing out the new hero blackā¦ although not 100% about the tires this vid, more in the worksā¦ but hypersmooth and tires is niceā¦ will have to do same vid again once I finish this next build with PU
Just got my drivtrain with these tires done. now just got to paint the @Boardnamics mounts painted black !
You should move your motor mount closer to the wheel. Oh I see, you canāt. since you used a short mount, you have to flip the motor pulley and that means the motor mount as to be away from the wheel.
The motor pulley canāt be flipped as the mount is so thick that it takes a lot of the length of the shaft away. Do you see anything majorly wrong with the way it is now. Btw is the pulley intentionally designed to be put on the other way?
Yeah, pulley goes the other way. otherwise it puts a bending moment on the shaft. not good in the long run.
How many teeth in mesh do you guys have on the motor pulley? Is 5 enough?
