Decided to document this setup in its own thread to showcasing the performance and invite discussions. It was also brought to my attention that I was spamming the no words thread. I agree, it would be best to wait until the project is done and reserve the incremental updates to this thread.
What is needed(3D printed Pulley + 3D printed pulley adapter)
Now I wait for 2 weeks to receive the other 3 wheels so that I can test it on a board.
I don’t have long axle trucks to properly test the wobble, but I did spin it on a normal truck and didn’t notice any wobbling. Can’t say anything about balance. How do you guys test for that?
My experience has been mostly positive with these hubs and tires. I took a slightly different approach to the wheel pulley. I utilized the 3 hub bolts to attach a 3D printed adapter that fits the profile of VEX Robotics versa pulleys. The pulley presses onto the spokes of the adapter and then (3) 8-32 bolts hold the pulley in place.
I’m running enertion motor mounts with 15T motor pulley and 345-5M-15 belts. The wheels run quite true, I’ve had them up to 35 mph no problem on 12s5p/FOCBOX.
That is really good to hear. I am looking forward to riding mine. I really like your idea too. My current design is very strong but likely over-engineered(And hence higher cost to 3D print). I want this to be a super inexpensive setup for people to get into pneumatics.
I might try out your setup too on a second board that I’ll helping my friend build. This way I can compare them both.
BTW, around how many miles have you gotten on those wheels(+pulley)?
I’m currently testing something similar (inexpensive tire option with 3D printed hubs). Below I’ve posted my current 3D model as well as the tires I’m planning to use. Parts have been 3D printed, I have the tire from amazon, and the bolts to screw them together come in Thursday.
Main reason I’m testing these tires is they’re super inexpensive (they were on sale for $5 each at the time I purchased them). They are from amazon which means they are super accessible and quick to receive, and they’re semi pneumatic (no airing them up) which is technically less maintenance at the expense of customization.
I’ll post the 3D models over here as well at the end of the week assuming they work well after I’ve tested them.
Design looks nice, but I don’t think these tires are mean for anything serious. From amazon: “These tires are ideal for hand trucks, lawnmowers, utility carts, and other lawn and garden equipment”. So basically not meant for speed. But be safe when testing them.
The 6x2 tires are however proven to be reliable around here. You could get them from
https://psychotiller.com
or if you don’t mind waiting for 2-3 weeks from here:
Apparently there is a discount of 15% in 6 days.
Sure but who cares about axial load when you have a factory made grub screw hole in the motor shaft? As I said this is for 5065 motors that also have the added benefit of having a cut shaft (=perfect for experimenting with 3D printed gears) plus grub screw. You can even buy them with a thread on the motor shaft - axial loads should thus not be an issue.
A bit confused. Where is the grub screw located? The axial load will get transferred to the bearing which are built to work mostly with radial load. I think that’s what he’s talking about. Am I missing something?
You can probably go with double helical gear which 3D printing won’t care about. As for the drive double helical gear, one can even get it printed in metal(SS) if machined part is expensive.
@Maxid i too use DYNA beads in all my 3d printed rims and motorcycle tires… i have NEVER had issues w/ buying my tires online and mounting them at home using those beads
We should ask @Nowind if he upgrades his motors or how he deals with the axial load in his helical gear drive. From what I see I think he does not upgrade anything and the normal bearings are ok with being used like that.
