better than the stock one and really simple to install
Send me a pm pls. Or contact my by instagram
Come to my home and i will flash you the firmware and set up you’re bleuthooth module
@Grozniy @koralle @Acido @brenternet @bartroosen12 If any of you has some time to go over my electrical diagram it would be very much appreciated I only have basic wiring knowledge and want to be sure I got this right. Thanks in advance and already a big thank you for the help so far
Looks good. Haven’t seen that b0 yet. 10s balance Port has 10pin.
@koralle Ooh then I probably looked at wrong example diagram. I based myself on this image. This is for the bms I’m planning to buy from you btw :). So I should just drop the ground wire to b0 and then it’s ok?
That diagram is correct. There no b0
but what’s the unused pin at the bottom for? Bellow b1.
Do you mean b-? That is labeled correctly on your drawing.
No, below battery1 there is still a pin, there are 11 pins. On the picture ate least
OK you’re right it’s there but irl it’s not soldered to the connector.
Ok got it will update diagram. Sorry for all the questions but these bms threads get me really confused. Some say ignore the postive lead of the packs and then with these bestech ones it says ignore ground lead of the packs, very confusing
