Hey guys,
I really like the boosted board mount bracket and was wondering if it would fit around a 63mm motor if it was custom made? and would it fit on a dual build…
pics:
http://bestelectricskateboards.net/products/boosted-board-dual-plus.jpg
Hey guys,
pics:
<img src=“https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/2X/8/89bd2a50eb435d43f7ca8a4aca7cfb6468697a40.jpeg” width=“366” height=“500”
Don’t think the original motors are 63mm … Mounts need to be modified or replaced with ones that can hold a 63mm motor
If the trucks are Calibers as in the picture…then getting a mount is easy
I have Paris trucks, but i was wondering if i was to custom make some to fit 63mm motors but in the style of the boosted board, would it work?
Just wondering as i haven’t seen anyone try it here
Sure what not
Boosted boards used smaller motors, not sure if they still do. I recall that maybe they were scorpion motors… Probably 40-50mm diameter.
I’ve seen these with measurements. Was thinking of adjusting some measurements to fit the trucks and motor…
No prob using Paris trucks DIY Skateboard has mounts I think that will fit Paris…you need to confirm with @torqueboards
I just got printed a cover for the pulley which is kinda half of what you’re looking for. I do need to find/make a part to print which will be the piece right next to the belt. I’ll let you know how things turn out.
That sounds awesome, thanks
