New to posting and my first build so please be gentle if I’m being a dumbarse! I’ve just purchased a vesc from Maytech which is hardware version 4.12 but apparently has firmware 3.3 The latest version of bldc tools I can find supports firmware 2.16 and 2.18 and it’s the only version I can find, if I try to connect it tells me it can’t because the vesc firmware is too old (I’m assuming its actually because its newer but it can’t tell that) Is there a newer version of bldc that I can use or can I safely downgrade to 2.18 Also what happens if I just use it as is, as it seems to run fine. I’m guessing at the very least I’ll kill my lipo’s prematurely by over flattening if I keep running till it dies but will I hurt the vesc motor etc Cheers! Sean
You sir are a legend! all sorted. Thank you
You sir are crazy!
I am. Only a bit though sir
Gday, I have the same problem, what is the solution, the link he sent didn’t direct me to anything with help.
Gday, what is the vesc website for?
@ChummierNewt download one of this one. they all the same, you can just decide how much you ready to support the open source project. https://vesc-project.com/vesc_tool
