why do you need a 2A charger for the BMS? can’t you use a charger with a higher amp value?
of course you can, but a 2A charger is the minimum and it extends the life of the battery.
HI, I have bought this 6S BMS here but it has only 5 wires for balancing?! Do you know how is the wiring done in this case? Can this even be used for balance charging 2 x 3S batteries?
