UPDATE #1
I decided to go for a single drive instead with some higher quality parts. I still need to find some parts but here is the updated part list: The board:
- 1x $40 - Deck & griptape: 9 plies of canadian maple with darkwalnut finish from Skateshred.com (https://www.skateshred.com/wholesale-blank-longboard-decks/downhill-kicktail-dark-walnut-deck.html)
- 1x $70 - Enclosure: Knuckles enclosure from @psychotiller (https://psychotiller.com/product/knuckles)
- 1x $200 - Wheels, trucks, bearings, risers, mounting hardware, motor mount, pully, belt and drive wheel pully: Kit from @torqueboards (collections/single-motor-mechanical-kit/products/single-motor-mechanical-kit)
Electronics:
- 1x $100 - Vesc from @torqueboards (collections/esc-speed-controller/products/torque-esc-bldc-electronic-speed-controller)
- 1x $120 - 6347 190KV Motor from @torqueboards (collections/electric-skateboard-motors/products/electric-skateboard-motor-6374-190kv)
- 1x $60 - Remote and receiver from @torqueboards (collections/remote-controller/products/torqueboards-2-4ghz-nano-remote-controller)
- 1x $45 - On/off switch from @fottaz (https://eskating.eu/product/anti-spark-power-switch/)
Battery:
- 65x $300 - Samsung 30q batteris from eu.nkon.nl (https://eu.nkon.nl/samsung-inr-18650-30q-3000mah.html)
- 2x $8 - 1 meter 0.10x0.15cm Nickel strip from eu.nkon.nl (https://eu.nkon.nl/nikkel-battijersoldeerstrip-10mm.html)
- 3x $10 - XT90 male and female connecter from @fottaz (https://eskating.eu/product/black-nylon-xt90-connectors/)
- 1x $5 - Charging port from @fottaz (https://eskating.eu/product/dc-in-battery-2-1mm-socket-with-dust-cover/)
- 2x $8 - 223mm heatshrink for the battery from @fottaz (https://eskating.eu/product/heat-shrink-for-esk8-lithium-battery-packs-1m-various-size-tailored/)
- 1x $10 - Battery indicator from @fottaz (https://eskating.eu/product/battery-percentage-lcd-display/)
- 2x $4 - Insulation paper for the batteries from eu.nkon.nl (https://eu.nkon.nl/isolatie-papier-18650.html)
- 20x $15 - Random sizes of heat shrink for wires from @fottaz (https://eskating.eu/product/heat-shrink-tubing-10cm-4-various-size-tailored/)
- 1x $30 - 42V Charger from @fottaz (https://eskating.eu/product/2-amp-charger-10-and-12-s/)
Car battery spot welder:
Extra:
- 1x $5 - Waterproofing the battery case ish from @fottaz (https://eskating.eu/product/soft-black-gasket-for-enclosures-perimeters-1m-tailored/)
- 3x $4 - Velcro from @fottaz (https://eskating.eu/product/peel-n-stick-polyester-velcro-10cm4/)
- 2x $12 - 20 units (2m) of black and red 12 AWG wire (https://eskating.eu/product/10-12-awg-silicone-wires-in-black-red-10cm-various-size-tailored/)
- 1x $9 - T-Tool from @torqueboards (collections/accessories/products/skateboard-t-tool-blue)
- 1x $8 - Metric hex tool from @torqueboards (collections/tools/products/metric-hex-folding-tool)
- 1x $7 - Sensor wires from @torqueboards (products/vesc-sensor-wires)
- 1x $2 - Male to male servo connector from @torqueboards (products/male-to-male-servo-connector)
TOTAL: $1072 excl. shipping
Parts i still need to find:
- Foam pad for the battery
- BMS
- Parts for spot welder
I expect to pay $150 for shipping and $200 for the rest of the parts which will give me a total of: $1422
I might downgrade some of my parts or find other solutions since its $400 more than i expected it to be.
