Does any one have any suggestions/thoughts on this?
If possible, I’d like to attach my enclosure without having to see a bunch of extra screws on the top of my boards - I think I’ve seen on some builds from @longhairedboy and some others where this was accomplished.
Maybe extra plys of wood on the deck are necessary for the enclosure to be secure?
Okay - but I am planning on using clear grip tape or Lucid clear grip tape spray and am looking for a way to preserve the wood deck look without having like 15+ screws showing
You could use the wood dust and wood glue to add that on top, i saved the dust from my board and i mixed it in with wood glue and put it in the holes.
Was able to restore my deck to brand new, cant see where i drilled holes was even able to return it to the store for a full refund since i only drilled the holes.
But if the deck is thick just drill untill your close to the top and use the wood things you screw into it and use short screws with a little threadlocker on it.
Look closely on the side of the pack I have wire hooks. They are glued down and underneath the pack is 2 layers 3m foam tape. Gonna strap it down and 6 screws m4 will hold only the enclosure and its own weight. Hope it works
I’m using the slotted ones as pictured above - 5mm, they are pretty sensitive for hole diameter and a smear of epoxy helps for sure, might have better luck with the furniture type ones…have ordered a few to compare.
You can measure deck thickness (sometimes varies a bit) and put a piece of tape around the drill bit to tell you when to stop drilling
that works a treat for sure. I also use a white line of paint from a paint pen, it seems to cause less distraction as the tape wants to fly off, and sometimes it moves.
Do what I did…
Deck is 10mm buy 10mm wood inserts. Put wood insert on grinder take 2mm off. Drill, 8mm holes.insert the insert. Boom not all the way through
Special drill bit tape…just existed it now actually like your method better [quote=“longhairedboy, post:17, topic:44119”]
[/quote]
