Iām totally building this board. I got more questions for you @Pryside . I wish you would update the post with more details. That would be nice to share the complete part list.
Is 60 AMP enough for BMS? Should I buy one with higher or lower current?
I found a smaller version that supports 20A and found another with 100A.
https://www.lithiumbatterypcb.com/product/13s-48v-li-ion-battery-pcb-board-54-6v-lithium-bms-with-60a-discharge-current-for-electric-motorcycle-and-e-scooter-protection-2-2-3-2-2-2-2-2/
This question was answered and I went with the 60A BMS:
https://www.electric-skateboard.builders/t/noob-question-thread-ask-your-questions-here/9559/6937?u=farnamweb
Are you using the following motor mount ? Is there a cheaper alternative?
https:///collections/electric-skateboard-motor-mounts/products/single-bolt-on-motor-mount-set-only-black
What is the belt length? 265?
I can buy LG HG2 for $3.5/cell. Same capacity and extra 5 AMPs ( 20A) . Should I get HG2 instead?
This was answered here: https://www.electric-skateboard.builders/t/noob-question-thread-ask-your-questions-here/9559/6950?u=farnamweb
Will buy 30Q
Has anyone modified the code so it will work with the āTTGO LORA32 868/915Mhz ESP32ā 128x64 screen? Iām trying to build the Firefly nano remote but I would love to have features like an Odometer and cruise control on it.
Iām using an I2C 128x64 Oled. Not ready to share yet tho. Never tested.
Can you send gerber files? Thanks (What is that 8 pin for? next to Q3ā¦) I guess 3 pin Mosfet could be used right?
just use another wirewound resistor like r6, should be fine, with a quite high power rating. Dont really remember wich one I picked and on my PCB there will be some changes and a quite different precharge fet and resistor to save space.
Will publish all Antispark stuff very soon
Thanks man
I got this mount and belt . The mount has an idler which is interesting . The seller calculated the belt length for me. Itās 320
@matiller helped me find the resistor
https://www.mouser.com/ProductDetail/Ohmite/TUW5J1R0E?qs=sGAEpiMZZMtbXrIkmrvidMPY4i6h3AHP%2BV%2BE2e384xE%3D
Iām way to excited to finish the board. Do these changes affect the performance of the board or are they just saving space?
What are your VESC settings for breaking?
putting a tvs so high up there will destroy its purpose, most transcients wont even reach the caps since you have some inductance from the wires. Put it directly on the pcb as in noiās picture
-75Amps on the Phases and -10A on the battery are my max settings. May seem high but again pulsed this is perfectly acceptable. Safety is more important then getting 2 more cycles out of your battery.
is it possible to buy a anti spark from you? would love to build your board as well
Please verify the wiring.
BAT - >> BMS B -
BMS P- >> not connected to anything
BMC C- >> charger port & Anti Sparkās B-
- I just got my Loaded Vanguard Deck. The top has a clear grip coating. Do I still need to install a grip tape?
btw, Loaded is selling new factory blemished decks for $148
https://www.amazon.com/gp/offer-listing/B075NQGJJ8/ref=dp_olp_all_mbc?ie=UTF8&condition=all
There is one XT60 on the battery case for charging. What is the purpose of the other XT60 on the VESC case?
What size/length bolt and nuts do I need to attach the wheel pulley to the wheel ?
Iām assuming that I need to place a nut on the wheel pulley and bolts on the retainer. In that case, there is no room in the wheel pulley hole to hold down the nut using a nut driver.
So just to be sure: if you solder a diode that has a polarity you need to solder it with the minus side of the diode to the + of the vesc and the other on the - ?
Nice work. Clean, looks a lot like a boosted but much better Iām sure.
Butā¦ I will pick you on your numbers, haha.
5000w/50.4 = 99 amps needed. But hereās the catchā¦ at 20a, 30qās will drop from 50.4v to 46v while under power. At 35a, I canāt imagine what your dropping down to. With a 12s3p, the most power you can physically get from it is 60a at 46v (which is a full charged 12s3p 30q pack under load) = 2760w for more than .1 of a second. In that .1 of a second, the massive amp draw has little effect on operations, so itās a useless number to say you peak 99a. Thus saying you peak 5000w is kinda misleading, none the less advertising 5000w and not stating it as a peak number. Everyone defines peak and continuous differently. So you can twist the definitions so your not technically wrong. But the reality is your more likely using around 2500w max, which is high powered by the premade board market, but itās a very common watt number for a DIY board.
The problem with everyone misusing peak and continuous numbers is they make it hard to compare boards. I actually pull 10,000 watts for .5 seconds, which is significant in my case as Iām already at 15 mph in that half of a second. So I feel 10,000 watts peak is actually a fair statement. Do I just adjust my settings to 20,000 and say 20,000 peak? Iām sure I could hit close to that for .1 of a second, defiantly not the entire half second it takes me to do 0-15 mph as before.
Itās gritting in to the details, I know. But trust me, if you put a lipo in there that actually could do 100a and not sag into a black hole, you would still say your at 5000w and the acceleration would be night and day different, at least 30% faster acceleration. So because thereās no standard as to what these numbers are defined as and the lose definitions we have are bent so often, itās unfortunately really hard to compare one board to another without riding both (which is not possible 90%+ of the time on the forums).
Still love your design though. Just get a smaller 12s lipo for shits and giggles (like, $150 usd or less), and youāll see a large power increase.
yes connect it in reverse . but if you use a bidirectional diode like the one below, then you are good either way.
https://www.mouser.com/ProductDetail/Taiwan-Semiconductor/P6KE56CA?qs=sGAEpiMZZMvS4F1mNSR4OnsH6NOyMirV
I canāt get the remote working. I have uploaded the firmware for RX and TX.TX LCD lights up but I see the Voltage as 0. I also canāt control the motors.
- I have selected UART under āAPP to Useā and UART is set to 115200 under the UART tab. Do I still need to follow the āInput Setup Wizardā ? If not, how do I pair TX and RX ?
- I can enter the remote menu by holding down the switch and powering on the remote, but I donāt know how to change settings there.
- Do I need to power on the TX first and RX second?
Vesc : 4.12 with FW3.40
firmware : https://github.com/Pryside/FireFly-Esk8-NRF24/blob/master/libraries
VescUart Lib : https://github.com/SolidGeek/VescUart
