Hey fellow builders… Ive recently constructed a 10s 3p battery made up of samsung 30q batteries. Now my question would be, which bms would you guys recommend? The more the answers the better! Let’s hear what you’ve got!!
-Thanks
Ps. Here is a scribble of a diagram of what ive got. Let me know what you think. Its just a basic flex battery.
Side note: I want to build a new deck. Carbon fiber or tradition concave bamboo board?
Yes. Getting 4p or above also improves sag.
More p = more range/weight/ charge time
Nothing wrong with a 10s3p. Not every board needs to go on long distance trips.
A light board is a good thing too.
I recommend getting one of these bluetooth BMS’s. Being able to check that your BMS is doing its job(easily) will give you a lot of peace of mind.
You can also adjust just about everything you could think of. And if you don’t want to adjust anything, it comes pre-programmed with default settings that will work for almost everyone.
