Where should i put a buck module / UBEC for LED or USB port? Will it work? The motor is 245kv
Motor and battery combination looks fine, so does the anti-spark switch (at least thatās what I assume the yellow rectangle at the top is)
Iām a little confused by the black wire going between the two yellow rectangles in the middleā¦
@rpn314 I believe Koto is identifying the series connection of the two batteries at that point - as everything else is red-to-red and black-to-black. This is going to be a 8s setup, correct @Koto? It all looks good to me as well. 245kV will work. I will be running 8s on my build and I am using a 240kV motor. Check this out for more information about motor kV
Just out of curiousity, what are the rectangles labeled āFā at the corner of each battery?
Ah yes. I got lost in all the lines I guess. Sorry, itās the last week of my classes here for me. My brain is a little fried.
Ha, I understand that, Iām writing my graduate thesis in the library as we speak! Here we both are, one week before finals, playing on an electric longboard forumā¦priorities, right?! LMAO! This has been my brain break from the weight of deadlines crushing down on me.
Just to clarify, all yellows are connections (Xt90)
And the F was kind of mistake, it was supposed to be a female xt90
Well that makes three of us! @rpn314 @DreadBiscuit
This is more important than grad school, right? Right!?!?
yep, thats a series connection to make it 8Sā¦ hopefully
