Yes sir
10c
Yes sir
10c
He mentioned he is running FOC thoughā¦
Reporting backā¦ Hack did not work for meā¦ still jerks when it comes to a complete stopā¦
Dual 6374 running FOC on 8" wheelsā¦
EDIT: Also, reducing motor/batt mins didnāt work either, feels exactly the same
Damn thatās heart braking
What happens when you change to this? Does the board not come to a complete stop with this setting? I have belt skip at the end of braking when coming to a complete stop. Would be nice if you could disengage the brake when at say 1-2km/h.
It almost comes to a complete stop like 0.5kmh. But keeps rolling at the end. It brakes really hard as normal but as it approaches 0 the breaking force gets less and less, sort of a soft stop. I think my setting is a bit low, a little higher and I think it would stop. I think you have to find a sweet spot for your motors.
Same here. Iām on a flipsky with 6.6 Vesc and single Turnigy 6376 (https://hobbyking.com/en_us/dt6376-14p-sensored-motor-125kv.html)
Weird that has been so long and yet not fixed
How large wheels?
Flywheels 90mm
Strangeā¦ I donāt notice this on anything but my 8" wheelsā¦
I switched to current from watt on my gear drive and itās gone, did the same thing in my bludgeon but it didnāt change. This is a weird issue.
I feel it still my my sons 6s3p 14/36 83mm single drive.
Dual 6374 foc, ackmaniac 3.102, 97mm flywheels, 16/36, 12s4p,same issue in watt mode.
Digging up a buried thread hereā¦
Any resolution to this issue? Really irritated with my 8" AT board which likes to throw me off the board at very low speeds by locking the wheels.
Other speeds it works just fine, just that very last 1km/h it locks the wheels and flicks me off.
Nothing has fixed this issue for me even on my Jet Spud with 85mm caguamas I get this locking up.
Iām temporarily on single drive and also having this problem now
I can lock the wheel at any speed it not all my weight is on the driven wheel. For it to release I need to release the brake completely
Yesterday I did a nice slide because of this. Was braking with the wheel locked and decided to turn and full traction was gained. I liked it a lot since Iāve never did slide before
Thatās oddā¦ why are you getting this with 85mm wheelsā¦ I thought this was a ābig wheelā issueā¦
Just out of curiosity, is your spud on 12S? Because the only board I have problems with runs on 12S, the rest are on 10S.
Iām just trying to rule out things one by oneā¦
Yes, my Spud has 85mm wheels and Iām runing FOC. Itās not a wheel size issue.
