Wow. Thats a crazy large nyko kama reciever. I have not seen one like that before.
Well the pinout image is not the nyko kama, thats just the standard wiimote pinout i found on a site. I donāt know what device that is. Or are you referring to my actual photos with me holding the pcb ?
Anyway I just finished soldering it to the connector. I donāt have the vescs yet so canāt test it out, hopefully my soldering wasnāt too bad lol.
NICE!.. vesc art!.. looks cool.
Can you post a dia gram with the 7 pin connecter as im sure being able to see it will cuase less confusion because its not much mention and i would hate to fry my vesc cuase of wrong wiring @jacobbloy if you understand can you please post pic im checking diagrams jus wanna be sure of rite connection who woula thought one pin could mean so much i have no ifea what a adc2 is scares the hell outta me lol
What are trying to connect to the vesc, nrf24 or nyko Kama.
NRF24. VESC PIN8 IRQ -> not connected PIN7 MISO -> PIN7 SCL_RX_MISO PIN6 MOSI -> PIN6 SCL_RX_MOSI PIN4 CSN -> PIN5 SDA_TX PIN5 SCK -> PIN4 SCK_ADC_EXT PIN1 GND -> PIN3 GND PIN3 CE -> PIN2 VCC (3v) PIN2 VCC -> PIN2 VCC (3v) NONE -> PIN1 5v
Im using just the nunchuckā¦ so vcc is 3.3v i need for power and the triangle is ground? and i dont use pins 7ā¦ 4ā¦ 1 correct?
Iāve tried figuring this out for myself but have been unsuccessful so far, how can one turn the regen/brake feature off?
I am communicating by PPM and i wish to have this behavior: Reverse, Coast, Foward.
just so every one knows FOC is know available for the VESC, with FW2.3. Windows and OS X versions have been updated to 2.3 also.
Be sure to update your VESC before updating the BLDC-Tool. Seems to be having some issues the other way around.
looks like vedder just released 2.4 to fix FOC bugs
A little update for everyone. We have Vedderās spark switch set for production and will be offering it as a pre-wired package in combination with the VESC. It will come with a high quality sealed push button switch and auxiliary xt-60 charge port. As always the actual configuration is completely customizable by request.
When can I buy this?
I will have the first batch completed in a week, waiting on the pcbās. If you already have an order for a vesc I can send an invoice for the upgrade.
@jacobbloy, thanks again for your continuously updating.
It seems, that the mc_config_&_FW.zip is currently missing 2.4, also the OSX_BLDC_Tool_FW 2.3 FOC contains actually the BLDC-Tool V2.4ā¦
I basically scraped 2.3 as Vedder did some big bug fixes that he recommends every one to use, also you can get the fw file from git hub if your desperate I just havenāt had time to get every thing sorted.
No problem and Iām not desperate since Iām using Ubuntu and github anyway.
I was just asked by others not present here due to language constraints who are using the google drive solutions. But thatās ok.
The moment i get my servers back im just gonna setup a build cluster. I can even get access to some certs to sign the code so windows dont freak out about the app ever
just looking at that photo @chaka, I quite like the look and slim form of the VESC without any headers on it. got me thinking half the headers on there are not gonna get used, I might as well take them off.
like what are they all for anyway? the one on the baseline is for hall sensors right? well Iām never gonna use that. then there is the can bus, well i might link 2 togetherā¦ but only need 2 of the pins so I could just solder 2 wires. when my new Kamaās arrive iāll use the 7 pin header to connect the dongle, but again only 4 of the 7 pins usedā¦ If im using the kama then theres no need for the PWM pinsā¦ whats the other one for? flashing? I can do that with the USB. so probably donāt need that one either.
now that I think about it iād rather have no headers and just solder to the pads that I do need.
