Let’s get past this stupid trademark outrage and get back to the real thing:
@trampa, I’m a bit confused: 2-3 days from when? Will this be different from the beta version? (beta 1/beta 2, is there a difference between the two?)? Your webpage still states “DISCOUNTED ADVANCED PRE-ORDERS BEING TAKEN NOW!”. Could you please clarify?
I was referring to the VESC’s, that confused me because of the pre orders being on the page still. I understand now, I’ll hold off until you have it properly listed on your site.
When will vesc tool be available to the public? Will it be compatible with non-vescs based on vesc’s (4.12, focbox). What improvements can we expect? Duty cycle?
Sure, after BETA. The list of improvements is far to long to be named here. 100% new software, no old code, 100% new firmware, multiple hardware support incl. the old designs, setup wizards, throttle curves for different input devices, NRF pairing, update server telling you that updates are available, weekly updates, firmware integrated, no more looking for suitable firmware, automatic hardware detection, better graphs and analysis, better structure…it’s endless.
Basically a full restart of everything! VESC 4 will profit a lot from VESC-Tool. My VESC 4 runs a treat with the latest firmware. FOC is so much better now!
Once available, you can download it from Benjamin’s server, through www.vesc-project.com.
You will also be able to donate some $$ to Benjamin during the checkout (downloading) process.
People donating will get a nice bonus on top. Surprise!
Frank
A tiny detail I forgot: Benjamin integrated a full documentation into the Software. Question marks behind every single setting let you know more about everything, and will help you to understand better what you do or could do.
I believe the 6 will have an over-ride motor amp limit of 120 amps unfortunately. Just like the version 4. So while it could possibly put out way more power it’s being held back by the software and even if u put your motor amps past 120 it won’t go
Vesc® SIX by Trampamean Vedder is strong enough! Limit isn’t set by software. Vesc-Tool will tell you “you are doing something stupid” in case you drop in potentially destructive values. I think the DRV issue will shift towards cooked motors.
@jaykup Yes that is what I thought, just was not thinking of e-bikes due to this being an e-sk8 board. Trampa is a mountain board shop, so not sure why they would restrict it if mountain boards would need more? We will see if it is capped at 120amps or not Dual motors would be as much at 12,096watts.
@Trampa I’m aware that speed can be capped, but what about wattage? I mean say, at 5% charge, the wattage is 1,500 per motor, could I put a cap so it stays at 1,500 watts per motor when fully charged and there fore the max wattage the motor uses is the same through out the battery charge range?
At low duty cycle, (low speeds) the “effective voltage” is reduced way down. At 5% duty ur at 5% max speed and 5% of pack voltage. The math there brings the wattage way down at the lower speeds. Multiply using maybe 2 or 3 volts.
Just explaining how I came to this line of thought.
I set max ESC amps at 40 so it would be 80 amps max with two ESC’s.
What I did was calculate the speed at low voltage by going 10 series to make the voltage 37v as you can see below. Top speed weighted is 35.96km/h. Lets round it at 36km/h
Now when the battery is fully charged in the esk8 calculator by going 12 series to get 44.4v, I get top speed weighted at 43.16km/h, lets round it to 43km/h
What I assumed to do is at max wattage on low voltage of 37 would be 37 times 40amps = 1480 watts for 36km/h
Fully charged at 44.4v would be 44.4 times 40amps = 1776 watts at 43km/h.
I cap the speed at 36km/h so I get 36km/h when fully charged and still get the same top speed till voltage is down to 37v so I have consistent top speed for my commuting board.
I assumed if I also cap the wattage at 1480 watts even when fully charged, the power level would also be more consistent due to also capping top speed at 36km/h although I understand there will still be a bit more torque at full charge due to higher voltage.
In nutshell, consistent speed and wattage usage despite 100%,50% or 20% battery.
I’m saying if u hook up a wattmeter or an amp meter from the battery to esc you’ll find due to the way an esc works w pwm at low speeds there’s an “effective voltage”, which will be much lower than the pack voltage. At maybe 5% of ur max speed ur at 5% duty cycle and that means with continuous switching on and off, and a lot of off at so low a duty cycle, the motor will see 5% of what the pack voltage is. So while u can hit 120 motor amps, as that’s the software limit, the voltage u would multiply with to figure the wattage ur doing is…5% of whatever the pack voltage is. At higher speeds the duty cycle goes up, follows the speed, so u will hit max power at 100% duty cycle and at that point u can multiply using the full pack voltage
For example if u set ur max motor amp to 120 and battery max amps to 60 and u have 12s 50volts… At 5% of max speed you’ll still only have access to …120(close to) X 5v…so 600 watts.
The 6 is said to be able to do
Much much more but none-the-less the motor amp limit limits power out at low duty/speed
Ahhh, now I’m starting to see what you are getting to. Going up a mountain may be a bit slow therefore 5% not gonna work unless you jack up the amps for torque at low speed due to low duty cycle.
I only knew if battery is nearly flat, need more amps but not if battery is full but you want to go slow and need torque at the same time.
im saying if ur going very slowly and hit full throttle, even if ur batt and motor amp limits are set to their Max, u won’t get near the power output possible of the 6 until u go faster
