What about motor timing ? I’m using 4 degrees cuz at 8 degrees the acceleration is still a bit to much. I tried it at 0 degrees and the acceleration was way to spoungy.
I use whatever the maximum timing setting is on my ESC. have never tried anything less.
I maxed out at 26 mph today on 8s and 15/36 gears 97mm wheels. Motor timing set at 4 degrees. Punch control set at 90% God I love having brakes now and these esc’s rock lots of fun adjustments with this programming card and I can take it with me to make adjustments along my ride. I wonder if having motor timing at 8 degrees or 16 would net a higher top speed.
Yeah man i told you that you wouldn’t you wouldn’t regret going car esc. They are much more skateboard friendly.
I just figured out that I don’t need a bec with these esc’s the red power wire just needed to be hooked up . the red wire on these esc’s are cut short so is not Used but it puts out 6 volts for a receiver. Wondering why the manufacturer did that ?
Probably so they could sell BECs.
I can go over grass and up any hill on this board
I have gone more then 500 miles on it so far . max distance on one full charge 55 miles. This thing saved me so much money in gas its not even funny.
Electric power is the future! 55 miles is completely insane though.
I Live at 40 Mph i hit 40 on the daily if i could go faster i would
