The mounts are meant for Caliber 2 50 degree, a standard for eSk8
I bought an enertion mount not sure if that helps
I am going to close down the group buy on Saturday (12/17/16), you have until then to order.
Hey so what motor mount was decided on as the final? Sorry if it was said I just had trouble figuring it out from scrolling through.
No problem. We are using @JuniorPotato93âs mount. It has a right and left side version. There are some pictures of it further up if interested
Ok, paid. I assumed since youâre taking new orders, that itâs okay to add. So Iâm now at 10s3p, 83mm wheel, 97mm wheel, 2vescs, 2 mounts, 2 pulleys. Thanks!
I wasnât able to add a motor, though. Looks like youâre out of inventory on the big motor (6374).
is the battery made of Samsung 25R ?
Yes, includes bms, switch, and 2a charger.
Quick question @JuniorPotato93 motor mount on caliber 2 44 degree ok or needs wedge riser compensate? Thanks.
@caustin Wedge risers to compensate. Otherwise the mounts will likely hit the board. Might be doable on 1/2 risers but wedges are better.
I had the understanding that the mounts were for caliber 2 50 degreeâŚ
I also just wanted to let everyone know if I didnât all ready. The shipping charge (if any) on the website is not accurate if you purchase anything from the group buy (escecially batteries). You will have to fork over some extra cash to get them sent out.
Perhaps I missed the previous comment but I wasnât aware of the additional charge. What kind of numbers are we looking at here?
It should not be a lot, 25-30 max for a battery. I still need to find the best and cheapest way to get it to you.
Depending on the additional cost, I may just want a refund. with $30 shipping we are gettting close the cost of a MEB battery. Probably should have mentioned that beforeâŚ
Not really⌠I donât think shipping will be more than $20 (California) will be the most expensive. I just threw the max out there so if it is that expensive it is not a surprise.
The mounts are designed for 50 Degree Calibers. If you compare 50âs beside 44â you will see that the missing 6 degrees would result in less space between then mount and the board. Itâs the same thing with enertionâs mount. You put that on 44âs and you will be touching the deck.
