Word bro – I wish I went the other way. The tufnol is crap, the wood backbone is crap… Jenso always invents shit out of thin air like this…just when you think it’s getting boring
Let me know if you do the energy chain… I might go that route or use @Kug3lis pre-printted PCB’s if dude comes thru with them… as I already drilled by board and put in inserts so maybe just redo my battery with PCB’s.
As you know trampa boards very well. Can you easily change vertigo trucks to hang 8inch AT wheels to gummies wheels?
As I’m going to make a mtnboard with dual 190kvs on 35holypro 16ply on ultimate trucks with 8 inch wheels. And bindings, then when gummies are in stock can they be stuck on the vertigo trucks?
Looks great Jens, any reason to not mount the steering damper on the front? wobbles tend to start at the front of forward moving objects and also an advantage of no clearance issue
I have one lonely 6384 APS motor it’s a thing of beauty power wise
edit: two steering dampers? cool!
Hey
For my undderstanding the wobbles start on the backtruck ?!?
I actually not tested it on the front only, it would be great if this work… all clearence issues are gone then !
General i dont have much time for testing actually, got problems with my shoulders and dont ride often.
These a whole bunch of physics involved and I don’t have esk8 experience in this at all only motorcycle where the front is not a fixed plane. With a board there are two unfixed planes given the bushings on both ends.
In saying that having the damper in the front may be beneficial to keeping the board headed in the direction needed, I’ll have to get this on the try list for 2018.
Had to reglue the Energychain the third time now )-; now i got some real industrial stuff which seems to hold up great… the Idea of the Energie Chain is nice but its no cool solution if you have to remove it again (-;
The Freebord binding are no bad solution, running actually without griptape and they give good support… but i will do some padding with neopren like on the Leiftech… its not comfortable without for me
Really love this tiny drivetrain… motors inside the 7Inchers
Dude, you keep blowing my mind with all of your amazing builds! It’s getting harder and harder to fight the urge to sell everything I have and just buy one of everything you sell.
This is almost my dream board, beautiful, just need more battery’s, I’ve been thinking in some ways of making a double pyramidal stacking near the trucks and flat on the middle to avoid bottoming out
How much time does it take to switch gummies to pneumatics or vice versa?
Thanks Pedro,
good idea if you need more battery, not sure how much more you could add ?
Switching of Wheels goes faster with a second set of Hubs of course…
thats the way i did…
front wheels only needet to change via the axle nut, done in 2 minutes
Rear wheels needet to deflate, axle nut, 5x M5 screws which hold the Hub on the Drive, done in maybe 5min
Really i would say max 10minutes with spare Hubs and a Powertool
If you have to change complete wheels on Hubs it will take longer… i would say 30minutes ?!?
Thanks, 30 min is doable for a weekend of off road
I did some sketches yesterday and if I manage to cram all electronics is less than 100mm length wise, which is doable, I can fit 10S10P with a 3D printed enclosure that goes from side to side, this without double stacking, you could go to 19S10P and the enclosure would be approximately 35mm thick, one day maybe, 9kg of battery’s and 100+ Km on pneumatics
