Awesome build! Why did you use 1/16" ? Wouldn’t 1/8 work?
The Rocket | 4wd hummies hubs | 4x chaka vesc | 10s4p LG HE2 li-ion | CNC milled veneer pressed deck
Thats a fat deck bro!
Maybe, the more times you cries-cross, the more strength the board has. ou do a normal gain, cross grain, normal grain, cross grain, ect… That, along with the glue, is why the board stays in its shape and has so much strgth. You’d be amazed at how few sheets it takes to have really good strength.
Just an update, I calibrated the voltage meters. So I can keep an eye on every cell while riding by doing some simple math.
Haha, doing math while riding the skateboard sounds like a bad idea. Why couldn’t you connect the volt meter between the cells so that you get just the cell readings?
I think that would be more helpful. But would look really lame lol
4.2 4.2 4.2 4.2 Etc lol
Not these ones because they require a separate power source (they have 3 wires, power source +, power source - and measuring -, measuring +). Unless I use 10 separate power sources (one for each screen), I need to link all the negatives together. Since the negative must go to the power source and each cell, I would be shorting the balance connector which I connect them to. So I’m looking at a 2 wire on instead. I originally pictured that in my mind @barajabali. It’s more so there for testing purposes right now anyways, as I’m trying to see how unbalanced they come from riding, and so far, not more than .3 a volt difference in 1 pack, not more than .1 a volt in the rest. But In due time, I will replace them with ones that say…
4.2 4.2 4.2 4.2 ect…
This entire build is very innovative. Keep the updates rolling! A video would also be really cool.
This build is amazing! Super impressed by everything here and cant wait to see more! One thing I wanted to mention was you said that the board drew 72A max across the board though I was wondering what your actual current is going full speed? If you where actually drawing 72A and you had, lets say, a 10Ah pack, you would kill your battery in 8 Min and 20 Seconds so I know thats not the case lol.
It is a 10 Ah battery btw, and no, I haven’t yet. It’s hard to know exactly what I’m pulling. On duals of the 90 kvs, I rode with my laptop connected, bldc connect, and recording the screen so I could go back and see what I pulled. On flat, the highest I pulled was 17 per motor, so 34 total. On a fairly steep hill, I hit my limit of 25 per motor (50 total). I suspect I hit that limit when climbing some steep hills still. But on flats and slight inclines, I’m sure I never get close. I do need to test it at some point, though its hard since I would have to ride without a lid, which means standing on my vescs and battery, which is not ideal. This is why having a way to have the vesc record and save this kind of data would be great, but no ones created something publicly available yet, so I’m in thew dark.
Watt meters I’ve found to be extremely inaccurate. On the same ride, the watt meter said I pulled 12 amps while the vesc said I was pulling 25-27 amps. I trust the vesc more, and the vesc numbers made more sense, cause there was a huge difference in climbing ability if I reduced to 40 amps, which according to my watt meter, I never got close to.
Now this was a different board, same vescs, same motors, same battery minus 1 extra p I added, and dual instead of quad.
But moral of the story, I believe I pull 72 on steep hills, but most of the time, I probably don’t pull more than 50 total. But it would be nice to do some tests soon and see.
this is fucking awesome effort. well done dude!
i been watching Roarockit videos this evening to learn the method so my Dad and I can start one together, and doing the size you’ve done with the battery channels etc seems like a monster task.
Thanks, it’s a lot of work pressing the sheets, especially getting the air out of the bag. Check you seal consistently. I had it break a few times, the worst being the lid as I stayed for 2 hours, left, came back 8 hours later and found the seal failed. It does happen, and if you catch it, press the seal again a few times, and it’ll only take a few pumps to get back to good pressure. It doesn’t completely fail, but you’ll notice that black mesh is just a bit lose. That was the first sign I picked up on, then around the edges was a little loose. Again, it was so minor, that it could be fixed with like 5 pumps (and it takes like 600 pumps or more to press it once you seal it after gluing), so keep a close eye on it. The first 2 hours are the most important, but you want it in there for 24 hours under max pressure, or it won’t be prefect.
Roar rocket actually gave me the idea with their pre-cut kits. I figured if they sell kits for pre cut boards, why can’t I pre cut them with channels with my cnc milling machine and glue them, like one of their kits. And it worked great.
Just to make the deck though, I probably spent more than 200 hours total. It took 2 months of time, cutting and gluing at least 5 days a week, sometimes more. Most of that time was the steep learning curve of making such a deck, so I could make it faster again, but it will still takes me a minimum of 30 hours to make 1 deck in 1 on 1 with the board time, more when you consider it takes 5 days to glue it all the way.
The other interesting thing is I just did my first full discharge and recharge, and the cells when discharged became slightly unbalanced, but charged up, I was able to let the charger stop. packs at 42.02. The highest cell is 4.202. the lowest is 4.185. Which was what I was at before the full discharge, so a BMS in this particular discharge and charge cycle would have been completely useless, and done nothing.
NO BMS FTW!!!
Yeah thats weird that you would have so much difference between the watt meter and the VESC. You should get a trust worthy voltage meter and set it at measuring amperage and have the board just on a table where they only draw around 5A with the wheels free spinning and see which is right, the VESC or the watt meter compared to the accurate voltage meter.
Yea, I need to do more tests, get to the bottom of it, and figure this out. But I know it can’t be that high, because in my test today, I started at 41.7v and ended with 37.6v. I have my vescs set to slow cutoff at 33v, hard cutoff at 32v (just in case cells become unbalanced and I don’t have time to balance them. In this test, I did a 4 mile run involving 9 blocks of steep uphills, 9 steep downs, most moderate ups or downs, and a few flat. I am willing to bet I could have done 6-7 miles in these harsh extremely hilly conditions at full throttle (cause that’s all I ever ride at). If I did my distance tests right, I could easily milk 15-20 miles. On flats, 12+ miles. But this is why I hate max range numbers. This and they don’t account for rider weight. If I take a 120 pound rider and give them a flat and downhill route, 20 miles no questions asked. Me being 200 pounds, its almost double the weight, so I would expect 10 miles. Companies never state how they come up with their range numbers, and I feel like some do just what I said to bullshit their numbers.
Also I thought you mentioned something about needing a switch for your board? I have a thread about a couple different switches I designed and I uploaded all the schematics and places to buy the components on there as well so you can build your own. I also sell them for $25-$35 if you dont feel comfortable making one yourself if your interested. THREAD
Can do you an 80 amp version?
Yeah I could though like I said it would be overkill and I think my 60A dual 7530 version would be completely suitable because of its peak at 760A. I could do an 80A version with two IRFB7530-7P though that would be more like $40-45 because I would have to order like 10 of them from Mouser. Though I could definitely do it.
I might try it some time in the near future. I need to find out what amps I really am running. And I got the dyi switch in the mail today. So I’m going to hook it up tomorrow and see how it goes.
Alright good to hear and I hope whatever you do works.
