the sensored cable from my 6355 motor is small (10.43mm wide male) while the female connector on my vesc is about 12.85mm wide. How may I connect the sensored cable without having to cut and solder? I tried looking online for an adapter piece but I don’t even know where to begin my search terms. I’ve search the forums here and there but I haven’t read anything about the sensored cable-connector discrepancy. Does anyone know how I might fix this problem?
That’s what I did to my motors and is 100% worth it. Make sure you plug it in the right direction otherwise the VESC will not recognize the Hal sensors.
Only the GND (black) and VCC (red) need to match. It doesn’t look like there’s a temprature sensor, so the remaining wires can be connected in any order.
Once connected, launch the BLDC Tool, click “Motor configuration” tab, then select “BLDC” and click “Start detection” (labelled 1). The results of the hall sensor order will then need to be entered into the Table (labelled 2).
