@psychotiller revisited. Defend yourself @psychotiller !!
Nahā¦Iām tired
I wouldnāt recommend anything on the market since every mount Iāve owned broke. I made one myself that still hasnāt broken. Copy of enertion mount but made fully in steel. Not for sale. I never tried ollin mount but from pics it looks very well designed. My advice is for the ppl designing thier own mounts. They need to improve thier designs.
any pics dju cnc the mount?
yes the metal on the sides is thin but making it from steel fixes that issue.
@Evan_Byrne yes ur mounts added thickness should help alot. and u dont have too many holes. just note maybe the bottom part/clamp with all the holes isnt as strong as it could be. the screw heads are countersunk and that also reduces the material and strength at that point. but those screws heads look only 2mm thick. so u still have a good 6mm left there.
Guys I am not sure if that mount is any good - I circled the spots I think are too thin.
they are tough, i bumped to huge rock before but just scratches. but my enertion copy is with CF mount so milage may differ
If you are designing your own mount, why tension the belt by creating two separate parts? The X shaped mounting pattern for motors is only required if you plan on mass producing the mount and making it compatible for several motor types. Most designs here are a compromise to allow mass production and customisation.
Iād machine it all out to a single piece and just tension it using the motor mount holes. Also no need for an adjustable angle that I see elsewhere.
but the problem i experience that motor can doesnt hold a lot of torque. i striped by tightening too much. with large surface area and big bolts enertion copy is very good in this regards
You missed a spot! Bahaha
hmm, ok. Havenāt experienced that with the SK3ā¦but itās a good point/has crossed my mind.
Does anyone know the dimensions of caliber 2 trucks? I want to make my own motormount
