sounds amazing!
Awesome configuration tool build!
Would add ollinboard decks/components. Also I think longhairedboy now has enclosures he is making as well (or outsourcing?).
yep they work great. I have a tiny drawer full of them now.
ordered 1, looking forward to it!
Can we add chargers to the list? 6S, 10S and 12S chargers?
Great idea. Do you have any particular chargers in mind to add?
iMax B6 and iMax B6 V2
Great post for newbies like me!
How would one use this to charge Lion batteries? If I do a 6s4p battery setup with Samsung 18650s, would this be able to charge it? Thanks
No it wouldn’t. This is charging the pack to a much higher voltage as denoted by 10S vs 6S. I am sure there is a plentiful amount of brick style 6S chargers. Usually the lower the voltage the more common it is to find em.
You might to make sure you have a BMS to charge with this charger. The BMS will balance your individual series up packs and will make sure the pack is charged at a safe Voltage and Current.
What is BMS?
battery management system
As Link said, it stands for Battery Management System. It basically makes sure that the battery is not overcharged or over discharged. BMS units can also balance the parallel packs in a battery. It essentially keeps your battery within safe operating limits for you.
You can read more here: https://en.wikipedia.org/wiki/Battery_management_system
These guys make some decent BMS units: http://bestechpower.com/
How can you prove it?
